sbc inneed of medical attention 911 - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
  #91 (permalink)
Old 05-10-2013, 09:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Actually that first link has the revised link to Valve spring tech.
If the info you copied above was from Lunati, it's prollably OK. If I see anything that needs pointing out, I'll do so but like I said the info is likely just fine.
The Following User Says Thank You to cobalt327 For This Useful Post:
sweetlil66 (05-10-2013)
  #92 (permalink)
Old 05-11-2013, 02:16 AM
sweetlil66's Avatar
Here is my cam http://www.summitracing.com/parts/sum-k1103/overview/
Do i need to worries about anything other then having the right springs?
How do I find out what my springs are???? He just put them all in a baggie?
Colbelt Thanks.
And thanks to everyone of you guys! This means alote. Bless yall!
  #93 (permalink)
Old 05-11-2013, 10:45 AM
sweetlil66's Avatar
When I look at my cam on summit racing. I see a link that says suggested parts. Should I go ahead and just get new springs and stuff? The bag of springs I got from the shop should work according to the tech?
Suggested parts.
Springs - http://www.summitracing.com/parts/sum-174001
puhsrods - http://www.summitracing.com/parts/cca-7812-16
Altho I do not have the money for this- It will be aleast 3 weaks.
Thanks.
  #94 (permalink)
Old 05-11-2013, 11:46 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
A cam kit is useful only when nothing else was altered like decking the block or cutting the heads or changing the rocker ratio.Then you have to go through and check everything.
The Following User Says Thank You to 1Gary For This Useful Post:
sweetlil66 (05-12-2013)
  #95 (permalink)
Old 05-11-2013, 11:53 PM
sweetlil66's Avatar
I ordered a Valve Spring Height Micrometer, 1.400 to 1.800 in. Range = http://www.summitracing.com/parts/sum-900032
From summit today. When it get here ill check the specs. Can some one fill me in on how to read it?? and what it should read for my cam? Is there away to check my springs that i got from the shop?
  #96 (permalink)
Old 05-13-2013, 01:49 PM
sweetlil66's Avatar
Can anyone tell me how to use the height gauge?
  #97 (permalink)
Old 05-13-2013, 02:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You will use the height gauge to replace the valve spring. Watch for any steps on the underside (spring side) of the retainer that could throw off the reading. Be sure the valve is fully seated and the gauge is square to the spring pocket and the retainer, AND that the top of the gauge is reading from the same surface of the retainer that the spring will contact.
Once that's established, read the height on the vernier scale. If you need help reading the actual gauge, do a search for how to read a vernier caliper.
sweetlil66 (05-17-2013)
  #98 (permalink)
Old 05-13-2013, 04:26 PM
sweetlil66's Avatar
Thanks cobalt!!! My next question is how do I tell the straight of the new springs?
  #99 (permalink)
Old 05-13-2013, 04:27 PM
sweetlil66's Avatar
Iv looked for valve spring pressure tested but there out of this world on price. GRRRR any other way with out spring anther 100$ plus?
  #100 (permalink)
Old 05-17-2013, 01:47 AM
sweetlil66's Avatar
I got the height reader today. Im showing 8-25 intake and 8-40 exhaust. Iv got all the springs changed. I got some more info but I home maybe some one can tell me if my reading are good so far.
Ill post more in a bit.
Does anyone got a valve spring compressor tester for sale? cheap?
  #101 (permalink)
Old 05-17-2013, 02:01 AM
sweetlil66's Avatar
Ok advice please. Should I try and test the valve springs the shop said I should use or should I get the springs summit list under recommended parts.
This are the parts they say I should use.
Im gonna post a video on the engine soon.
  #102 (permalink)
Old 05-17-2013, 03:05 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
That would be 1.825" and 1.840".
Not sure of your specs, just wanted to show you how the numbers on your height checker work.
The Following User Says Thank You to 123pugsy For This Useful Post:
  #103 (permalink)
Old 05-17-2013, 08:46 AM
sweetlil66's Avatar
Thanks pugsy. Im thankful for that info had no clue have to read that thing and google can some times (GOD BLESS GOODLE) make it a lil more detailed then needed.
So if i understand this process at all- I need to go threw every valve and get its height. Then I need to get a shim that brings that height down to or up to 1.700 in.
Thanks again guy.!
  #104 (permalink)
Old 05-17-2013, 12:48 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Shims go under the springs I believe. So the top of the spring stays at the same place, the shims just bring the bottom up until the height hits 1.700".
Intake needs exactly 1/8" (.125'') and exhaust needs an 1/8 plus .015".
Seems like a lot but I'm no expert on these things. Do you know what thicknesses are available?
  #105 (permalink)
Old 05-17-2013, 01:57 PM
sweetlil66's Avatar
Thanks for your reply Pug. I havent hard a chance to look at shims yet. I take care of my wife who is disabled and my 1 1/2 year old son so it hard to work on the engine.
I have almost checked the right bank of the engine and will post all the specs tonight.
So far -
cylinder - 2 had I-8.90 E-8.80
cylinder -4 had I 8.50 E-8.55
cylinder - 6 had I-8.75 E-8.70
I could have a few of those specs backwards but the numbers them selfs are right. I wrote it down but its in the living room and I run the chance of waking my son if i open the bed room door to leave.
I checked with the shims installed.
I did pull the shims to read what they said- They all say. (This side up) *V.S.I. 203*
medical nos BLZR81 Engine 4 01-23-2010 06:32 AM
Medical Oxygen Regulators ? kdc49 Garage - Tools 21 04-04-2006 09:52 PM
What are your medical conditions? lluciano77 Hotrodders' Lounge 62 12-01-2004 11:03 AM
medical question 40fordtruck_son Hotrodders' Lounge 28 10-17-2004 01:18 PM
New Medical Breakthrough Kevin45 Hotrodders' Lounge 8 06-23-2004 10:09 PM
