Originally Posted by Cape Cod Bob
I know I've read here that I can put a vintage intake manifold on a late model 350 that has angled bolt holes,TRUE?
Can I also use my vintage distributor?
'90 sbc late 60's intake dizzy and water pump. etc.
Thanx for any help
Are you referring to the 86,87 up heads with the 2 center bolts at a different angles or Vortec type heads? If NonVortec style heads the center holes on your intake can be ground to work with newer heads. If Vortec style I don't recommend drilling those for oldstyle intakes because of sealing problems. Distributor & waterpump should be fine.
