SBC Intake help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2013, 01:22 PM
SBC Intake help
Newbie here. Seems all my Google searches lead me here so I joined up.
I recently just did my first engine build. Nothing major. Have an SBC 400 out of a 74 Caprice. Casting 330817, 2 bolt main, all stock. I just cleaned it up and put new gaskets in. I currently have the motor in my 87 K10 4x4 in front of a TH400. I'm currently into the offroading thing, but I'm feeling a change and want to get on the drag strip soon.
That being said, while I keep on my search for a car, I would like to have the 400 operating the best I can before I get a serious rebuild done with it. I have 2 intakes: one is a cast iron from an early 70's Vette and the other is an aluminum Weiand 8004. I'm wondering which is best for my setup? I daily drive it and will get on it sometimes.
Sorry for the long post for one question and thanks for the help in advance.
The Corvette intake is first, Weiand second.
Cheers!
Old 05-04-2013, 03:00 PM
The weight savings alone would justify the use of the Weiand as long as there wasn't alot of corrosion in the coolant ports/thermostat housing, and you don't need to install an EGR valve or a choke stove. IMO
FWIW,
ssmonty
Old 05-04-2013, 03:08 PM
Banned
sell the vette intake to the numbers matching, date coded anal vette guys..$$$
Old 05-04-2013, 04:18 PM
ericnova72's Avatar
More for Less Racer
FWIW,
ssmonty
I agree, probably won't be even a 4-5 hp difference between the two, with the advantage leaning to the Weiand...but the Weiand is a lot lighter.
Old 05-04-2013, 08:16 PM
vinniekq2's Avatar
what corvette did that intake come off of?
Old 05-05-2013, 06:38 PM
Thanks for the input. Definitely a bonus on the weight. The Weiand is in really good shape.
The vette intake is a 6263751 from a '72 350ci. Might put it up on my local classifieds if its worth anything.
Now when I swap intakes, do you guys have any tips for re-installing the dist without finding TDC again? Is there a better way to do it than eyeballing it?
Old 05-05-2013, 08:13 PM
Richiehd's Avatar
JS-70
Turn motor over to #1 TDC on the balancer and remove cap and mark Distributer where rotor is pointing. Drop it back in the same spot, check timing with light.
Old 05-05-2013, 09:26 PM
techinspector1's Avatar
Wiki Edits: 326
An ad in Hemmings Motor News will get the attention of fellows looking for gennie 'Vette parts.
sbc intake maxie2029 Engine 5 02-08-2011 12:03 PM
Which SBC Intake ? Eastex Jr Engine 18 05-09-2010 04:21 PM
sbc intake hottrodz Engine 1 12-12-2006 07:37 PM
Which SBC intake? HawkZ28 Engine 3 06-05-2006 07:51 PM
sbc intake chevypunk Engine 1 11-30-2002 03:37 PM
