sbc intake manifold ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2008, 02:13 PM
77-78 sbc 305..... intake manifold, when installing is there a plug that goes in the rear oil takeoff gallery along block rail, before installation, im new to the engine scene so if someone could help, it would be greatly appreciated.... thanks
Old 11-08-2008, 06:18 PM
boatbob2
oil plug???
Hi,if you are talking about the oil hole on the rear rail that the intake gasket goes on,,,i usually just put a screw in oil line fitting in the hole,then use RTV on front and rear (about 1/4 inch) of the front and rear rail.. plus a small bead up onto the side intake manifold gaskets (where the intake gasket meets the ,front and rear rail.,(1/8 inch of RTV should be enough) only up about 3/8 inch. be sure you use a fitting,or its almost guaranteed that you will fill that oil pressure guage hole with RTV.
Old 11-08-2008, 06:47 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Moving to Engine forum
Old 11-09-2008, 12:58 PM
new to the forum sry for the mis-post
GM SBC intake Manifold Retired Hotrodding Basics 12 01-04-2008 08:11 PM
460 intake manifold eddy Engine 1 11-09-2004 10:16 AM
Port ID - B&M 144 Intake Manifold blown81 Engine 0 03-01-2004 03:03 PM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 01:12 PM
Need some intake manifold help killerformula Engine 14 11-29-2003 11:07 PM
