SBC Intake manifold sealing styles..gaskets vs bead of sealant?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2010, 09:50 AM
Livin in ChevHelle
Hey fellers,
Just curious here, getting ready to go back together with my SBC(again) and was curious as to how you install your intake manifolds at the ends where it seals against the block(not where it seals against the heads).. Do you guys always use the little rubber gasket strip or lay a bead of hi-temp sealant?.. I have done it both ways..was JW..
Thanks
Old 02-14-2010, 11:19 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Toss the rubber gaskets/sealing strips and use Loctite/Permatex "Right Stuff", once you try it, you'll never use regular RTV again,
The Following User Says Thank You to Rickracer For This Useful Post:
MouseFink (03-29-2015)
Old 02-14-2010, 11:28 AM
4 Jaw Chuck's Avatar
I dimple the end rails with a center punch to prevent squeeze out and use silicone sealant, the rubber eventually cracks and leaks. Just make sure you let it dry overnight before starting up. I have never had a homemade silicone end seal leak...ever.
— Han Solo
Old 02-14-2010, 11:39 AM
Rickracer's Avatar
I generally scuff both surfaces with 80 grit, then clean with brakleen, either way will get you a leakproof seal,
Old 02-14-2010, 11:48 AM
I also Do not use the rubber strips, I use Permatex RIGHT STUFF, amazing stuff!
Old 02-14-2010, 12:37 PM
sqzbox's Avatar
My pipes are my music
Rubber strip
Oh MAAAAAN! And I trusted Fel-Pro! Maybe a good thing I used both.
Old 02-14-2010, 01:59 PM
Livin in ChevHelle
Hehe...that was my attack plan in the past, hated it, leaked shortly after the build. Ive done the sealant method, seemed to work, but Ive never knew which method you guys preferred...
Permatex Rite Stuff huh?
Old 02-14-2010, 03:07 PM
sqzbox's Avatar
Sealer or gasket?
I like the permatex high heat red. I ran a thin bead across the rail and set the rubber gasket on, then run a bead across the slot where the port gasket tabs set in the rubber one on the ends. Haven't had any leaks since I put it together in sept. 08.
I went out and checked just now so I wouldn't be blowing smoke and it's still dry across the bell housing.
Old 02-14-2010, 07:00 PM
Last wiki edit: Hand cleaner Last photo:
Wiki Edits: 3
i never use the valley gaskets.
i mainly use permatex ultra copper.
right now i have 10 years and over 150K on my daily driver with no signs of a intake leak.
Old 02-14-2010, 08:17 PM
Rickracer's Avatar
Originally Posted by Coletrane
...Permatex Right Stuff huh?
I guarantee, if you ever try it, you'll never use regular RTV again,
Old 02-14-2010, 09:49 PM
airboat's Avatar
It's moisture in the air that kicks it so if you want it to set quicker spritz some water on it or lay a wet paper towel over it...
Old 02-14-2010, 11:39 PM
sqzbox's Avatar
Will this work?
Old 02-15-2010, 08:07 AM
Livin in ChevHelle
EeeZee now...family forum here..better change that to a Ford logo.
Old 02-15-2010, 09:10 AM
Mertz's Avatar
I just pulled the intake off my 72 Chevy 350 because I suppected a gasket leak causing low vacuum at cruise. I used the hard blue flepro gaskets. When I pulled the intake I found oil in the runners. Leak confirmed. The good thing about the hard gaskets is they pulled right off with no scraping.
I am reinstalling a 2101 Edelbrock with Edelbrock gaskets. I lined them up with the ports on the head the best I could. When I went to lay on the intake some of the black lines were exposed on the top part of the gaskets. I also had to pull the valve covers so I could raise the valve cover gaskets so I could get the new intake gaskets high enough. Did I get the wrong gaskets? It doesn't seem like there is enought tolerance between the openings in the gasket and the ports on the intake. It is not completely installed yet so now would be a good time to change them if I have to. I really don't want another internal gasket leak. Any good way to check for leaks before everything goes back on?
Right Stuff is excellent but pricy. I have used either black or blue Hi temp RV without problems. The Edelbrock gaskets don't even come with the rubber or cork end gaskets. If you get them just toss them and use sealant.
Old 02-15-2010, 10:08 AM
The directions with my Edelbrock Performer EPS manifold said specifically to not use the hard Fel-Pro gaskets, since they would not seal right. They provided the Edelbrock parts #, and an equivalent Fel-Pro number that was recommended. I used that Fel-Pro gasket, and have not had any problems with the seal.
I also found that I had to pull the valve covers to allow space to get everything to line up. I used a bead of RTV to seal the ends.
I also got some small block-off plates included with the manifold gaskets, but did not use them. From what I remember, the block offs matched up with flat areas on the block, so they would not have done anything anyway.
You m
Aluminum Intake Replacement on SBC 31fordcoupe Engine 5 12-08-2009 12:47 AM
Changed intake manifold gaskets now lifters extremely noisy strokey Engine 16 06-27-2009 01:36 PM
Torque link intake manifolds? xxllmm4 Engine 10 06-12-2009 07:20 AM
intake manifold gaskets... camarokid87 Engine 1 08-25-2002 01:20 PM
adapting early sbc intake manifold to 1987 350 heads steve curtis Engine 1 06-13-2002 02:56 AM
