Smearing rtv on a spot that is already leaking is a hack job...Its like painting over a prior paint job with out prepping the surface to bond the new paint.
I like the vacuum idea if you can keep from sucking sealer into the engine.
rtv
I think we all have had a leak after a fix at least once. You might think you had it clean but maybe not. After wiping with brake clean take a clean dry rag over it again. Then take a piece of blue painters tape and touch the mating surface, if the tape sticks your good to go with the 1/4 in bead of rtv. Don
You can cut a couple of long bolts of the proper thread and use them as alignment pins. I have done this in the past on hard to install intakes. In most instances you will only be able to put them on one side due to the angle the bolts go in at but it can really help, especially if you are working alone.
Artificial Intelligence is no match for Natural Stupidity Chet |
Brylcream ?
Like the old Ad, A Little dab will do you, His cars were always show quality when he sent them out, wipe off the excess when he couldn't hear the whistle with his stethescope
Great idea! Man...The stuff you learn after the fact! Will ad this to my list of to do's when/if I end up pulling it again. Thanks |
the vortec intake gaskets are reusable if they haven't been on the engine for 50k miles, Don't waste your time trying to suck RTV into the leak, you will never get the old RTV clean enough for it to stick, just pull the intake and do it right.
Funny , last time I put my intake on , I had a small leak at the back , cleaned the area w/ alcohol , forced a little silicone in the offending spot , stopped the leak [that was 2 years ago & it's still dry !!
dave |
you got lucky.
Cole
| intake manifold leaking oil | 1972 El Camino | Engine | 3 | 11-07-2011 07:40 PM |
| I Believe my Intake Manifold Gasket is leaking. | El_camino69 | Engine | 3 | 10-25-2011 10:46 PM |
| leaking intake manifold | poisonknives | Hotrodding Basics | 16 | 01-06-2009 06:51 PM |
| Intake manifold leaking oil | TheRidler | Engine | 11 | 11-21-2008 04:59 PM |
| Leaking Intake Manifold | Regal Beagle | Engine | 15 | 05-27-2008 02:01 PM |
