SBC into 88 Ford Ranger Ext. Cab - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2005, 09:40 PM
i was woundring what all i would need/custom to put a sbc into my 88 ford ranger, it came with the 2.3L 5 speed, will a chevy manual fit with out taking out my fire wall? and will the shifter go in the same hole even? same question for the clutch. i know i would need motor mounts and a drive shaft and cross member work, anything eles? thanks alot.
Can i keep the ford tranny and biuld it to V8 spec and put a bell housing on it to fit my chevy? thanks.
Old 05-28-2005, 07:20 AM
GoneNova/406's Avatar
i do not have that info for you but if you check with these people they will be able to help with everything.
www.engineswaps.com
www.advanceadapters.com
www.jagsthatrun.com
www.v8monza.com
88 chevy 2 ton cab to 80 3/4 ton frame stoneyone2001 Body - Exterior 1 11-11-2003 08:43 AM
'88 Ford 302 EFI CustomFord Engine 1 04-14-2003 03:46 AM
How do I install dual side pipes on on 97' Ford Ranger? John Rose Engine 2 01-15-2003 05:38 AM
89 ford ranger/ tension pulley for serpintine belt/ anyone have one? Doug Lavery Engine 1 11-14-2002 05:36 PM
96 ford ranger 96ranger Engine 2 09-19-2002 11:40 PM
