sbc into an old Mopar - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2013, 11:42 PM
erauqssidlroweht
I have a 54' plymouth savoy with no engine but, I have the trans, needs re-sealed though. I want to put the sbc lt-1 head conversion motor in it. wondering if it would be best to have an adapter made from the trans for the existing driveline, or do a complete swap. The three on the tree would be pretty sweet with the sbc setup. probably be pretty close to blowing it or the rear end up though. I found these:
engine mount kit
Butch's Cool StuffEng & Trans Mounting Kits
blockhugger headers, or period correct 55' headers that swoop up
Summit Racing® Block Hugger Headers - SummitRacing.com
these guys make a rack and pinion for cheap for conversions like this because of the low center of gravity sbc's have when mounted interferes with the stock suspension. can also get cool stuff, like disc brake conversion etc. from them.
Home - PLYDO : the best in mopar parts!
looking forward to the unique concept of sbc in a mopar, plus the 12/1 of a lt-1 conversion
wish me luck. More info on making the lt-1 conversion would be greatly appreciated. That is the reason I started this thread.
Old 03-02-2013, 12:12 AM
327NUT's Avatar
PLEASE !!!! don't put a Chevy in it, find a nice running 318, 360, 383 Mopar with trans and install that. You'll be much happier in the long run and you won't get laughed at.
The Following 2 Users Say Thank You to 327NUT For This Useful Post:
LATECH (03-02-2013), malc (03-07-2013)
Old 03-02-2013, 12:47 AM
erauqssidlroweht
Not gonna happen.
Yeah....... I don't have any of those. I can't find a replacement engine. I'm not shelling out for a "cracked head" 318 or 360. I have sbc engines out the wazoo. I want something unique and budgetable. This is it. I have a ready made sbc that needs heads, everything else, working on the heads. The savoy Is already converted to 12v so no worries there. I'm not trying to win a popularity contest here. Just planning my build and asking for help with what I'm planning on doing anyway. The other project is running smoothly too.
Old 03-02-2013, 03:01 AM
Banned
if it was mine, I'd find a 225 slant6 add a 2.2 turbo and have at it..
I understand you have the sbc.. but you have 2 projects, you can hunt down parts for the mopar..
good luck with whatever you choose
Old 03-02-2013, 03:58 AM
zmaxmotorsports's Avatar
Id put the sb in there with a turbo 350 trans behind,cheap easy combination to find parts for.
The automatic would also make life easier on the stock rearend if you do leave it in there,only thing that would worry me is crossmember/oil pan clearance depending on suspension.
Stock exhaust manifolds may buy you some clearance also,Id mock up an empty block and heads with oil pan and valve covers to stick in there first to check for clearance before committing completely
Old 03-02-2013, 06:30 AM
Wiki Edits: 27
Rear end.
I would look for a later rear axle, I don't like working on the old tapered shaft-key drums, I think they still used the trunion u joints, go all modern, There is a wiki on converting to later axle shafts here on hotrodders.
Old 03-02-2013, 07:21 AM
vinniekq2's Avatar
the :lt-1" you have? what happened to the used ported vortec engine build?
post some pictures of the car
Old 03-02-2013, 09:56 AM
erauqssidlroweht
I thought about that, the slant six is my favorite engine besides the HEMI six, and I would love to have either one of those. for budget reasons I have to use what I have.
Old 03-02-2013, 10:02 AM
erauqssidlroweht
thought about that, It's too bad I gave all my powerglide, and th350 cores to my buddy at the driveline shop.
I have a 305, that I pulled from a kids 65' impala "ran it out of oil" I can use that to mock up the install. I'll post pics when I get it into the garage. It is going to sit REALLY low, as in, pan scrapingly low I have a set of ramhorns so I should be able to pull it off, either way. I got the approval of the route 66 car club here locally, they are rooting for me now.
Old 03-02-2013, 10:04 AM
erauqssidlroweht
I'll look into that, I know a guy with some old Mopar rearends lying around, he needs some work on his wifes car. May be able to trade.
Old 03-02-2013, 10:08 AM
erauqssidlroweht
double header, I have both. I have a buildable 010 2-bolt main block and the other block for the vortec build is in the shop getting bored/honed. Machinist needed to burn it to get all of the crap out of it, threw it back in the hot tank. Told me yesterday that the rust in cyl's 3 and 5 is not as bad as expected, and he may only have to bore 20 over. My machinist is one of those that says, "the customer is not always right, if you don't do it my way, find another machinist" he doesn't like to go "full bore" he only likes to bore as much as is necessary. $360 for the work is cheap, I would be hard pressed to find a better deal elsewhere.
Old 03-02-2013, 11:27 AM
.020 overbore machine work might be cheap but then you may need oddball sized pistons which may cost you more. Just bore it the standard .030 and get cheap off the shelf pistons. Overall this is more cost effective and simpler.
Old 03-02-2013, 03:58 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Should be pretty easy to sell some chevy engines you have to buy a nice MOPAR crate 360 for in the Savoy.
I have a SBC in my clothes washer, they come clean but I aint proud of it. LOL
Fact is stranger than Fiction
Old 03-02-2013, 04:14 PM
Hahaha,now that's funny I don't care who ya are!
Old 03-06-2013, 07:50 PM
hkestes's Avatar
48 Plymouth Club Coupe
"I want something unique"
So you are going to use a small block Chevy?
I agree with Latech, sell the small block and buy a 360, then it will be unique. Not only that but think about when you are ready to move the Savoy. Mopar guys are not going to want it becuase you bunged it up whith the Chevy, and Chevy guys are not going to want it because it is a Savoy. And lets face it a 54 Savoy is an acquired taste which the vast majority of non-Mopar guys are not going to invest in.
The Following User Says Thank You to hkestes For This Useful Post:
NintendoKD (10-12-2013)
Mopar best value barthmonster Hotrodding Basics 4 03-24-2009 11:40 PM
Mopar 440x2 Introduce Yourself 1 10-22-2006 12:49 PM
hello! Mopar anyone? JackieGasparic Introduce Yourself 1 05-13-2006 05:15 PM
Mopar 3.3 V6 Fordcrazy Engine 0 05-02-2004 09:39 AM
Mopar Only..... 56-Dodge Hotrodders' Lounge 18 04-10-2004 03:38 PM
