SBC, Iron heads DCR for Pump gas ! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-25-2010, 08:38 PM
techinspector1's Avatar
Wiki Edits: 326
Going by the efficiencies that I see on the DynoSim after doing hundreds of them, it is my belief that a low-rise intake manifold such as a Performer will be less efficient at filling the cylinder than a high-rise intake such as a Performer RPM or Weiand Stealth. If you aren't filling the cylinder as well, you aren't making as much cylinder pressure and the tendency of the motor to detonate, all other things being equal, would be reduced in my opinion.
  #17 (permalink)
Old 09-25-2010, 08:53 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
OK thanks tech. I am think'n that at lower rpm the smaller runner of the standard performer will fill the cylinder better due to a higher velocity and this lower rpm is were the load is highest. So scooting it in there faster is better in the lower rpm?,,,think'n out loud cause I have a eps performer. Wonder how the eps hold's up to this thinking, its more or less a high rise I beleive.
  #18 (permalink)
Old 09-25-2010, 10:40 PM
Wiki Edits: 326
Well, I guess it all depends on the rest of your equipment. The RPM is rated to begin making power at 1500 and I don't know anybody who is expecting to begin applying power to the tires with any less than a 2000 stall converter and some gear. I mean, if they are thinking performance at all. Maybe if you were using a stock converter and foot braking the motor against the converter you might get some ping, but that is the exception rather than the rule I would think.
  #19 (permalink)
Old 09-26-2010, 01:38 PM
Dirty Biker's Avatar
Bold As Love
Originally Posted by cobalt327
You know, I've no idea where you come to any of the conclusions that you so often voice here. But until or unless you have some actual hands on experience to back up these kinds of blanket statements, you need to type less and get your hands dirty more, IMO.
What I am getting at, is you have no experience- by your own admission you've yet to build a single engine, unless I have misunderstood you. I would think that you would realize there's a lot more to the engine building procedure than reading a few (or many) lines off the 'net. You are in no position to be giving advice- again, IMO.
I completely rebuilt a stock 240 ford six a while back. I have also rebuilt the kawsaki z1 I had, using 11:1 pistons and new valves. Both turned out well, I almost died in a wreck on the z1, that thing was pretty mean. You don't have to like me cobalt, I couldn't care less what your opinion is
  #20 (permalink)
Old 09-27-2010, 02:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That I have zero respect for you has nothing to do w/your ability- or lack thereof- to advise folks on their maladies.
Instead of "guessing", "supposing" or parroting something you read/heard/dreamt somewhere- i.e. cases where you actually have something substantial to offer- other than a WAG, fine. Otherwise...
An example that you throw out occasionally is
"I myself prefer more compression and less spark timing."
And jewels like:
I learned this because I sometimes back the timing down (sometimes too much) when pulling the trailer at high speeds on a road trip. It (retarding the spark advance) makes the motor feel more relaxed at 90 mph and I like to go fast. Hope I didn't confuse you, I didn't mean to. See what vacuum line goes to the distributor, I like the vacuum line that only pulls vacuum when you hit the gas. Some people use manifold vacuum.
I am sure somebody can word this better than me but you need a timing light and a piece of chalk.
Now, only an idiot OR THE UNINITIATED would actually believe there was an advantage in doing this, yet you toss it out there, apparently w/no regard for anyone who might be lured into actually doing something this lame.
You said something along the lines of "don't say anything if you can't say...". I would say to you, "don't say anything- period."
  #21 (permalink)
Old 09-27-2010, 02:23 PM
And jewels like:
You almost sound as crabby and intolerant as myself.
  #22 (permalink)
Old 09-27-2010, 02:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Just when you think the idea had finally sunk in... then here comes crap that's 2 weeks old- apparently he craves attention- no matter from what quarter.
  #23 (permalink)
Old 09-27-2010, 06:02 PM
Guy's Chill out ! I appreciate all your help, Because some of you are real hotrodders with real experience making my life easier. As in helping me with my engine for the Off road Jeep.
Which unfortunately I haven't reached final decision yet. Not because of F-Bird's grate answer. Just because I am thinking about going to bigger tires, and which if i should use manual transmission and on and on....
Sorry guys.
Best regards.
Monzter...
  #24 (permalink)
Old 09-27-2010, 06:28 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Amen. I really dislike reading the threads where you slog through two guy's posts who are verbally attacking each other, back and forth, because they each believe they are the authority on a subject. If you disagree, simply and objectively state what you believe and let what you wrote on a subject stand on it's own merits. Statements such as 'I have zero respect for you' and 'I couldn't care less what your opinion is' shows me I shouldn't seriously consider either one of the parties as an authority. Let's keep it helpful and civil.
  #25 (permalink)
Old 09-27-2010, 06:43 PM
Normally I'd agree but dirtybiker gives a lot of bad advice, and its going to cost the poor sob who follows it. Unfortunately their isn't anything the mods will do in regards to someone repeatedly posting horrible advice as long as they are civil in doing it.
  #26 (permalink)
Old 09-27-2010, 07:18 PM
Wiki Edits: 326
I'm not so sure about that. ap72 was always civil.
  #27 (permalink)
Old 09-28-2010, 08:29 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'll let my "helpfulness" stand on it's own merits or demerits- as viewed by those who I've tried to help. I do NOT give a whit whether the 'regulars' here like me- that is not why I am here. Nor do I judge the regular's efforts by whether or not I "like" them, either. This is not a popularity contest! It IS about sharing good information.
The biggest "help" that could be done in THIS case, is to muzzle the bad advisers- not those who call them on it.
AFA civil, if you don't like the tone/timbre of my posts, it is very simple as to how to not be bothered by them.
  #28 (permalink)
Old 09-28-2010, 08:42 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Amen brother . Preach it . I couldn't agree more . If I give bad advice I would want somebody to tell me . I wouldn't want to be the cause of somebody's equipment failure .
Lt1 Heads: Iron Of Aluminum? USA1 Engine 12 12-08-2009 09:59 PM
Whats what with sbc heads? bwomp969 Engine 13 06-27-2009 11:43 AM
SBC Heads -= AFR - Trickflow - Dart - Brodix =- Delirious2000 Engine 25 04-22-2009 01:58 PM
getting old iron heads to flow? (SBC) KNanthrup Engine 9 12-21-2005 06:06 PM
'76 400 SBC cracked heads 87Camaro Engine 5 04-19-2004 12:01 PM
