SBC knocks up to 1300 rpm, then goes away - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2012, 12:47 PM
Hello everyone,
I just bought my forth c10, 1977 with 350, th350. The engine is bone stock 4bbl quadrajet, adjusted the valves, just did plugs, wires, cap, rotor, new vacuum advance(old one leaked), new mechanical advance springs, one heavy one light, adjusted the carve and got timing where I think it needs to be, no timing light yet. It fires up on a dime, pulls pretty good. My problem is when in gear, giving very light throttle I have a "knock". Above 1200-1500 its gone. And at idle its not there. I can't figure out what it is. Any help would be appreciated.
Thanks
Old 01-21-2012, 01:22 PM
DoubleVision's Avatar
The knock you hear is likely detonation since you dont know what the timing is set at. Until you know the timing don't run it again as you can do damage.
Old 01-21-2012, 01:27 PM
I thought that but with it Going away I kinda decieded against it. I have retarded the timing and it seems to go away but then I have no power, can't even spin the tires in wet dirt. So figured that wasn't it.
Old 01-21-2012, 01:53 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Might be a rod bangin around. Does it knock for a short time when accelerating lightly right before it upshifts?That would be a classic telltale rod gettin loose kinda knock.
Old 01-21-2012, 03:24 PM
No, it only does it up to about 1300 in first gear. I don't hear it after that.
Old 01-21-2012, 03:48 PM
68NovaSS's Avatar
Wiki Edits: 9
Renamed your thread to help get more responses.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 01-21-2012, 04:14 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
^times 2. Use better fuel until you can rebuild the motor with true flat-top pistons and a tight squish.
Old 01-21-2012, 06:36 PM
crazypj's Avatar
I fake being smart
You have mechanical advance distributor, check the springs are fitted correctly
It could be going to full advance too soon?
Get a timing light (don't need an expensive one if you only use it a few times a year)
You will be able to see if ignition is advancing smoothly or even advancing too fast
Harbor Freight cheap 'strobe will work well enough for what you need
Old 01-21-2012, 07:55 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
your carb is very lean at that rpm range, maybe the power valve is stuck or the jets are wrong, even maybe a small vaccum leak can make that problem.
but definitely you must set the timing first.
Old 01-21-2012, 09:08 PM
Don't know if this is important, but it also is after it warms up some. And could it be spark knock or timing with it going away after 1400 rpm and only in gear? Sorry its just a new situation that I haven't delt with before. Thanks everyone.
Old 01-21-2012, 10:07 PM
Augusto's Avatar
only after it warms up you can get the correct air fuel mixture, also you'll never hear an engine knocking in neutral, they knock under load while driving.
Old 01-23-2012, 09:17 AM
Update.
Checked mixture and plugs for signs of running lean, plugs are light brown as they should be. Checked initial timing and it at the 2 on the left side of the 0, 20*? Is that too high? The truck fires up like its on good time, and if I back it off like I said I can't even spin the tires n wit dirt, so if it is too high what could be causing the lack of power.
Thanks again everyone
Old 01-23-2012, 09:41 AM
Make sure your flexplate isn't cracked. They can knock like that at low rpms, also. Hole to hole at the crank bolts.
Old 01-23-2012, 09:55 AM
I thought about that but if it was the flexplate wouldn't it do it all the time at low rpms. Sometimes this knock I'm having doesn't happen, or atleast isn't noticable.
Old 01-23-2012, 10:29 AM
Not necessarily. The one I had crack, the noise was intermittent-that's what made it so hard to pinpoint.
engine knocks but only wen in gear??? DeanHinds Engine 5 01-31-2011 04:22 AM
1000-1300$ project whatsamotor Engine 4 05-03-2009 06:55 PM
1300 cc vw motor MRGM Engine 6 07-09-2007 06:36 PM
383 knocks/pings after 1st gear 72Nova383 Engine 3 09-15-2004 11:02 AM
knocks 19firebird72 Engine 7 12-23-2003 11:27 PM
