sbc left side alternator mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2006, 10:12 PM
Last journal entry: dash mods
I have a '76 sbc with lwp. I have the A/C compressor mount for passenger side but I'm unable to find or figure out what to use to put the alternator on the drivers side without laying out big bucks for brackets.Any suggestions?I want it mounted high like the a/c. thanks Cisco
Old 08-15-2006, 11:02 PM
MI2600's Avatar
Member# 3287
This is the lower mount for the driver's side alternator. It bolts to the first two bolts of the exhaust manifold. The upper mount (no pic) is a curved arm bracket that bolts to either the front of the intake or the water pump and is slotted for adjustment.
Old 08-16-2006, 12:05 AM
isn't that a short water pump bracket? i have long wp. Cisco
Old 08-16-2006, 11:54 AM
Dave E Shank's Avatar
HEY CISCO:
a company called Allen Grove Componets www.alangrovecomponents.com 913-837-4368 manufactures a complete line of special mounting brackets... PONCHO
Old 08-17-2006, 08:48 AM
What about the mid-late 70's Corvette accessory mounting system? They still have the left hand mounted alt and the A/C mounted high on the right side. Not sure if they still used the short water pump for the Corvette or not though.
Old 08-17-2006, 10:16 AM
Mustangsaly's Avatar
I have a all Original 72 Chevy p/u thats factory a/c on passengers side top and alt on drivers side, I can pop the hood when I'm home and take a pic 4 ya.
Mustangsaly
Postive ground but negative coil, strange one Nightfire Electrical 21 04-19-2006 06:20 PM
400 SBC Steam Hole Crack ezobens Engine 5 03-20-2006 08:28 AM
2000 Toyota Tundra left signal stays on dan1 Electrical 1 12-19-2005 04:52 PM
sbc rod side clearance 85406 Engine 4 06-11-2004 01:32 PM
Matching Crunched FG Frt End, Right to Left Turbo2Sam Body - Exterior 2 04-24-2003 10:19 AM
