SBC Lifter/pushrod question after removing intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2008, 10:41 AM
Removed intake to investigate potential internal vacuum leak that was sucking oil from lifter valley into intake ports (previous post on major oil blowby problem); anyway the intake ports were bone dry. However I did notice (4) raised lifters which I was unable to twist pushrods and another partially raised lifter that I was able to twist the pushrod. Is this of concern ? Pics below (left and right side).....any info would be of great help. thanks.
Old 09-27-2008, 10:51 AM
j.d.brown.042964's Avatar
406 Caprice:Rust Never Sleeps!
That is normal. Those are the camlobes that are currently either opening or closing a valve. The reason you can't spin the pushrods with your finger(s) is the fact they are currently "under load". -Jim
Old 09-27-2008, 11:01 AM
Thanks Jim, I feel like an idiot. I know they were under load but I guess I got mistaken by reading another article stating that if you can't spin the lifters they were bent.
Now to investigate valve guides as potential souce of oil consumption
Old 09-27-2008, 12:18 PM
406 bug's Avatar
9.82 @ 139mph
Don't forget to change your oil after you button things back up. Looks like You have some coolant that snuck into your crankcase.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 02:10 PM
Best SBC Drag Race intake for $200 - $300 nastynova Engine 2 09-08-2007 10:17 PM
350 Intake question oregon chevelle Engine 4 02-17-2006 06:27 PM
pcv/ intake question sfd771 Engine 4 07-19-2004 09:50 AM
another intake question BanditT/A Engine 12 10-19-2003 12:12 AM
