SBC Long water pump or short water pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2008, 03:16 PM
how to tell difference between long water pump and short water pump on small block chevy - the a/c has been removed and the alternator may have been moved to the passenger side?/
Old 04-22-2008, 03:24 PM
If the back of the pump is about 1/2 inch away from the timing cover, it's long. At about 0 clearance (maybe a sixteenth of an inch) it's short.
Pat
Old 04-22-2008, 05:11 PM
wretched ratchet's Avatar
one full turn after it squeeks
Here's mine - - is it long or short ?
Old 04-22-2008, 05:49 PM
Wretched ratchet ... yours is a SHORT style Chevrolet water pump.
As a general rule ... if you can get your index finger in between the water pump and the timing chain cover ... it is a long style pump. A short style pump fits too close to do so.
Old 04-22-2008, 05:58 PM
thanks, I thought it was but wasn't sure enuff to say so
Old 04-22-2008, 10:00 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Yours actually looks like it might be a marine pump with the dual-pattern pulley bolt holes, but you're right, it is a short pump.
Old 04-23-2008, 11:08 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Also notice how the first groove on the crank pulley sits right against the dampner? That is a dead giveaway of a short water pump.
Old 04-23-2008, 11:45 AM
Actually, most rebuilt and aftermarket SBC water pumps now come with the dual pattern on the pulley mounting flange
Old 04-23-2008, 12:01 PM
if it hadn't been short, my radiator project would have sucked and failed
Old 04-23-2008, 04:35 PM
cabowabo's Avatar
big Q
whats mine short or long ?
Old 04-23-2008, 04:39 PM
looks like a short one to me - - -right, Guys???
Old 04-23-2008, 09:18 PM
uuuhhh, couldn't you give us a little bigger picture??? i can't ever hardly see the front of the engine, much less the water pump...
...with the drive it's bound to be short.
Old 04-27-2008, 11:56 AM
66Chevelle's Avatar
This one look like a short pump? Based on Deuce's post, I'm assuming so. I'd also heard that if the plug was vertical, it was a short, and if the plug was at an angle, it was probably a long. So I'm fairly sure this is short but just looking for a little confirmation before I dive into trying to acquire an alternator mount. Can't provide any useful make/model info, as this is a 350V8 transplanted into a 65 Nova. I'm not positive of the origin of this engine as it has one of those very common codes - 3970010. The stamp up by the head is ML22800, which I haven't been able to accurately cross reference.
Old 06-27-2008, 09:34 PM
A picture is worth a thousand words ...
The Following 2 Users Say Thank You to Deuce For This Useful Post:
andrewakessler (08-27-2013), malc (04-19-2015)
Old 06-27-2008, 10:27 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Here's something I learned from motorchrome.com, and it seems to apply to both SBC and BBC.
Waterpump : This bracket is for small block Chevrolet engines with long water pump and will mount the alternator on the passenger side of the engine just as the factory brackets do.
LWP: Alternator mounts on passenger side.
SWP: Alternator mounts on driver side
The Following User Says Thank You to 66GMC For This Useful Post:
malc (04-19-2015)
long or short chevy water pump? 97Z28 Engine 10 04-24-2013 09:23 PM
Big block water pump on small block! TVR383 Engine 14 04-15-2008 07:43 AM
Water pump. Long or Short Zeater1 Engine 5 07-04-2005 07:09 PM
sbc water pump syclone Engine 5 09-22-2004 08:02 PM
SBC 350 WATER PUMP pitsen3 Engine 1 01-13-2003 10:02 AM
