sbc losing something - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2009, 09:24 PM
i have a 1980 k5, everything is new. but when i get driving it will fall on its face and act like its running out of gas when running down the road at a steady pace,replaced fuel pump , distributor,fuel filters, and carb. still the same prob,, any ideas
Old 05-12-2009, 09:29 PM
fast68's Avatar
likes chevy trucks & boobies
is the bowl filling up in the carb ?
perhaps there is a kinked line or hose under the truck or at the fuel pump,
check hoses there and at the tank for a kink etc.
i have found this problem in the past when this problem has happened.
it doesnt take much either, the pressure is only 7-9 psi when non-restricted
so..
check everything carefully under the truck
if still no luck then i would remove the hose at the fuel pump from the frame rail and get an air hose and pressurize the fuel tank with a rag in the filler and see if a crud clog comes out
good luck
Old 05-12-2009, 09:41 PM
i pulled the tank but i didnt blow thru the lines,another thing is when i turn it off the fuel filter between the carb and mech. pump drains down is that normal one guy told me it could be the pick up coil, but i changed out the hole dist. and i still have the same prob.
Old 05-13-2009, 05:58 PM
T-bucket23's Avatar
Wiki Edits: 26
Check the fuel pressure with a gauge while it is happening. Dont buy anymore parts until you know what the issue is.
It sounds like fuel,could be the pickup in the tank is partially plugged or a twisted line. A fuel pressure test will prove it one way or the other.
Chet
Old 05-14-2009, 10:34 AM
bobjob's Avatar
check cat. converter.i know it sounds wierd, but company truck had same sounding problem.tried the same thing to fix it, still same problem.boss claimed NO WAY it could be converter,when he left for a couple of hours, we built a tube and changed with converter. worked good and is still in truck. our county in az. considered rural .no smog laws yet.
if exaust can't go out, pressure will build up.no flow no run.
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
What to consider when choosing your first SBC build? CandiMan Engine 16 05-25-2009 07:50 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
SBC Still fuel fouling plugs, Losing my mind! 67 Deuce 4 Me Engine 9 09-02-2005 08:56 PM
