sbc low oil pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2009, 02:43 PM
1967chevelle454's Avatar
Last journal entry: Before Retoration Begins!
my 327 has recently started to run low oil pressure. It usually runs at around 20psi idle and 30 highway. It now runs like 5 psi idle and 23 highway. Any thoughts?
Old 02-27-2009, 03:38 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
oil pump? bearing clearances opened up some allowing the oil to run out? oil viscosity? but I really believe it's the pump, the pump is a high ware item, it draws unfiltered oil & has a fairly course screen, so anything in the oil that can remove some material from the gears & or pump housing will do so, & will over time increase clearances & will lower your oil pressure.
Rich
Old 02-27-2009, 03:44 PM
bondo's Avatar
Ayuh,.... Change the Oil,+ Filter,....See if it Helps,... Cut apart the Filter,+ look for Crap...
Old 02-27-2009, 04:31 PM
noodles56's Avatar
Had a smiliar issue, changed the oil and oil filter. oil filter was super clogged with crap. Oil change is probably the simple fix.
Old 02-27-2009, 04:48 PM
Jmark's Avatar
How many miles on the engine? What weight oil are you using? When was it changed last? What brand of filter?
Old 02-27-2009, 06:02 PM
your not running the adapter for a oil cooler , and have it plugged off .
low oil pressure... gearhead81 Engine 13 03-12-2009 06:54 PM
low engine pressure molevolent_creations Engine 14 12-24-2005 07:49 PM
low oil pressure TWOPLYM Engine 10 07-26-2005 10:07 PM
SBC Oil Pressure Problem....!!?? chevyelc81 Engine 8 07-25-2005 03:40 PM
Low Oil Pressure on Buick 3.8L V-6 TravisT Engine 8 03-31-2004 10:12 AM
