sbc main caps - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2008, 08:45 PM
sbc main caps
how can i identify main cap locations if they are not numbered
Old 02-17-2008, 09:04 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
I center punch mine.One dot,two dot,And so on.
Old 02-17-2008, 09:21 PM
King of my Man-cave.
If they have gotten mixed up, it is possible to locate them properly. You can eliminate #5 of course........
Look at the cap's and block's mating surface for each cap. Look carefully for any scratches, lines, dents, or any other marks that will differentiate that area from another. Usually you will find corresponding marks that mirror each other on the cap and block interface. Each cap and corresponding block mating area will have unique marks.
Good luck.
tom
Old 02-17-2008, 09:46 PM
the only reliable way, is to do as machine tom said and then check them with a dial bore or inside micrometer.
sam-missle
Old 02-18-2008, 07:21 AM
CNC Blocks Northeast
Good luck.
tom
I second the motion!!
Horsepower rating for sbc 4 bolt main block? beemdubya Engine 15 10-29-2009 05:52 AM
400ci SBC missing 4-bolt main caps? wayfast77 Engine 6 12-05-2005 09:47 AM
Splayed main caps on a factory 4 bolt SBC block? flyin99 Engine 2 11-24-2005 06:48 PM
anyone know the main and rod clearances for sbc? bullheimer Engine 9 04-15-2004 10:32 AM
Oil Galley Plug Under Rear Main on SBC??? camaroman7d Engine 16 02-19-2004 02:30 PM
