sbc markings - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2008, 01:21 PM
sbc markings
does the 010 on the side of the block signify anything i've heard that it means four bolt but i'm not sure
Old 04-01-2008, 01:40 PM
Jmark's Avatar
the 010 block is a very common block, usually a 350 2 bolt or 4 bolt. Only way to ck is to pull the pan and look.
Old 04-01-2008, 01:46 PM
so does the 010 mean anything
Old 04-01-2008, 02:13 PM
NOPE......it just means you are looking at a chevy block--->
Old 04-01-2008, 02:16 PM
OK cool but if i remember correctly i think i read somewhere that it means that there is more nickle or something and that it's stronger?
Old 04-01-2008, 02:20 PM
starnest's Avatar
elkyholic
Last journal entry: Center Link Installed
010 is 10% Nickel
Actually from some research I did on small blocks, the 010 cast into the side of the block signifies the percentage of nickel used in the iron for the casting. The 10% nickel content adds strength to the iron.
Old 04-01-2008, 02:23 PM
so it does mean something and it is stronger then because i think i got that from Mortec.com
Old 04-01-2008, 02:59 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
That is just a myth, all blocks from that era had comparable amounts of nickel in them. Sometimed they put 010 on one side and 020 underneath it. So does it have 10 and 20 percent nickel? nope.
Old 04-01-2008, 03:07 PM
I think the whole nickel tin thing is a big myth also. It supposedly means 010 is 1% nickel and 020 is 2% tin. Correct me if i'm wrong but If it was 10% nickel and 20% tin it would no longer be cast iron.
Jordon
Old 04-02-2008, 02:47 PM
starnest's Avatar
elkyholic
Jordon
Actually 10% was a typo, it is .010 or 1%. And I wasn't there, but from what I understand the earlier castings did not have any markings and the nickel content was negligible.
When high performance and heavy duty applications (early to mid 60s) caused blocks to fail, they started adding nickel to strengthen the blocks. By 1970 almost all blocks were cast with 1% nickel content, thus all of the blocks had 010 in the castings.
As for 020, my understanding is 2% nickel was used (I hadn't heard of using tin). I've never seen a block with 020 casting.
I can't recall where I read about this, and as always even if it's in writing, don't make it so.
Old 04-02-2008, 03:08 PM
XNTRCI-T's Avatar
AKA Lee in KC
My block has both 010 and 020 on it. It is a '79 350 out of a truck, 4-bolt. I have heard the 1% nickel - 2% tin explanation many times, including from the racing engine shop that built my short block. I don't know for sure if it's true, but it does help me sleep better at night!
Old 04-02-2008, 05:21 PM
DoubleVision's Avatar
Is the casting number 3970010? notice it ends in 010? this is common on these casting number blocks cause its part of the casting number. The past rumour of that 010 marking on the side indicates a 4 inch bore, but this has never been confirmed either as the true meaning, so it reflects back to what I just said, it means 3970010.
Old 04-02-2008, 06:12 PM
XNTRCI-T's Avatar
AKA Lee in KC
If you're asking me, yes the block casting number is 3970010. The 010 and 020 marks on my block are on the back of the block inside of the bolt circle for the bellhousing. I have a photo somewhere... I'll look for it.
Old 04-03-2008, 02:40 PM
The marks on the rear or under the timing chain cover 010 and 020 represent the percentage of tin and nickel in the casting as mentioned, but on the side it means elsewise.
Old 04-03-2008, 03:10 PM
I thought the only place the tin, nickel numbers were found was under the timing cover. That was the only place my engine had them ('76 'vette).
You are correct as far as any numbers on the sides.
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Lunati cam and 305 sbc questions in a Frankenstein low budget rodder Engine 13 06-30-2009 04:55 AM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
