sbc mated to '40 Ford tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2014, 02:25 PM
I have installed a 327 sbc in my '40 Ford. 14" flywheel, 10' Ford clutch plate, Chevy pressure plate, Crager adaptor. The problem is the '40 clutch linkage will not push the throwout bearing far enough into the pressure plate diaphram to disengage the clutch plate. Any ideas?
Old 03-27-2014, 02:45 PM
techinspector1's Avatar
Wiki Edits: 326
Did you get any kind of installation instructions and/or dimensions to measure from and to? If not, call and talk to Bob Bendtsen at 763-767-4480. He sells Cragar adapters and is a gee-whiz at mating anything to anything.
Old 03-27-2014, 02:51 PM
Thanks for the referral. The problem doesn't seem to be in the adaptor. It is pretty standard for this swap. The problem is the length of the clutch pedal rod and yoke end. They don't turn the rod in the transmission that pushes the forks forward far enough. I have put in a longer yoke end and it does depress the diaphram, but not enough to disengage.
alfa v6 mated to manual rear drive ebbrell Transmission - Rearend 10 11-29-2014 02:48 AM
700R4 mated to NP203?? 350cruiser Transmission - Rearend 5 11-23-2011 09:49 PM
I mated to the 40 to EZ wiring! Footstomper Electrical 5 06-30-2011 08:52 PM
700R4 mated to '93 4.3L Vortec TV Cable question 87GMCS15 Transmission - Rearend 4 03-22-2011 08:53 PM
has anyone actually mated up a T56 w/ their pontiac engine? Chirodan Transmission - Rearend 0 04-24-2006 10:49 AM
