SBC motor mounts - little problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2009, 08:58 AM
user151's Avatar
Building a car and I am at the "drop engine in" stage....
I have a crossmember motor mount in the frame, it's from TP (now Speedway). I put new mounts on the SBC engine (1960 type Chev V8 mounts). Dropped the engine in and the engine mounts don't line up with the frame mounts. The frame mount holes (tubes) are tighter by 1/4 inch.
Doesn't sound like much, I could "make" it fit, or I could go to the separate weld-on-each-side-of-the-frame mounts, but I'd like to know what the prooblem here is -- if any.
I tried NAPA mounts, then Auto Zone mounts, same issue (I see these are all mde in India now!).
But... could the frame mount be made incorrectly? Measuring between the tube centers, at the front and back of the tubes, I get 16-1/8 inches and 16-1/4 inches....
Anyone got a hot rod frame with SBC mounts (that fit your engine!) you can measure?
Old 02-27-2009, 10:20 AM
dawg's Avatar
NAVY VETERAN
it would be a BIG help knowing what car its going into?????
Old 02-27-2009, 10:24 AM
poncho62's Avatar
Wiki Edits: 5
I bet, if you loosened up the frame and engine mounts and wiggled them around a bit while lining it up, they would fit fine.
Old 02-27-2009, 10:31 AM
are the mounts rubber and bolted on the block , or the metal cup mounts ?
metal cups are different from the trucks and car .
as stated earlier , more of what it going in
Old 02-27-2009, 10:55 AM
user151's Avatar
motor mount......
The frame mount is a crossmember mount, see speedway no. 916-18012 -- the location of the mounts are not adjustable. This is going in a Brookville 30 - 31 frame.
Old 02-27-2009, 07:11 PM
T-bucket23's Avatar
Wiki Edits: 26
There are 2 different style chevy mounts. One is a little wider and flatter than the other. One is 2 5/8 and the other is 2 3/8 Wide between the ears. The wider one is also a little flatter.
Chet
Old 02-27-2009, 07:40 PM
user151's Avatar
I thought all 1958 - 64 Chevy V8 mounts were the same... I do have the wider ones which should be correct but there is some mis-match between the motor mounts and the frame mounts.
As I said, perhaps my frame mount was made wrong... anyone have a hotrod frame set up for a Chev 8 ? -- I'd like the measurement between the frame motor mount tube centers.
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
Fuel problem on sbc ARRGH agent spliff Engine 15 10-24-2007 06:48 PM
sbc timeing problem mrclean Engine 9 10-23-2007 06:40 PM
SBC hesitation problem 1953 Homer Engine 4 10-06-2007 10:15 AM
starter problem on sbc agent spliff Engine 3 09-23-2007 02:45 PM
