SBC/Muncie/bell housing questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 10:24 PM
munster217's Avatar
hi guys,
Pulling my hair out here...I have a 67 Camaro RS, 350 SBC and I'm converting from an automatic to a 4 speed. I have a 10.5" (zoom #30005) clutch and pressure plate with a 168 tooth flywheel. What bell housing should I be using? GM part# if you have it. Everything I am finding is for a truck (mounted that and found that didn't work without a conversion plate (no interest)) or 153 tooth flywheel. VERY frustrated at this point to say the least...you guys are the best so I bring it to you! Any suggestions?
Thanks so much...
Old 07-22-2012, 10:59 PM
munster217's Avatar
My current bell housing is an aluminum GM housing part #460486...should this work with my application?
Old 07-23-2012, 07:48 AM
Im not a GM casting number guy. However I will tell you that a GM Bellhousing for a car with a 4speed has a 4.75" dia register (middle hole). There are bellhousings out there for bigger clutches that had a 5"+ diameter hole.
If your bellhousing is the "11 inch clutch BH with 5 inch hole" I have an oversized front bearing retainer (the casting that the throwout bearing rides on), so you dont have to use the spacer.
The Following User Says Thank You to AutoGear For This Useful Post:
munster217 (07-23-2012)
Old 07-23-2012, 10:00 AM
munster217's Avatar
Okay...finding out some more info as I dig. It looks like I need a 3899621 model housing to work with my 168 tooth flywheel and accommodate the Muncie. I can also use a model 464697 if the ball stud is in the top location. Lower location will not work.
Thanks for the help.
Old 07-23-2012, 12:04 PM
WHy not run the 153 tooth flywheel? Its lighter and should accept the 10.5 clutch.
Old 07-23-2012, 12:09 PM
munster217's Avatar
No great answer other than I already have a 168 tooth resurfaced flywheel now and will need to replace a bell housing (460486) that won't work for my application anyway.
400 (SBC)flywheel/ bell-housing eloc431962 Transmission - Rearend 8 05-14-2011 08:48 PM
Dodge poly bell housing; what manual transmissions fit the bell housing? Hemi-Meadowbrook Transmission - Rearend 2 03-08-2011 08:07 PM
clutch bell housing questions dmaddox6 Transmission - Rearend 6 11-21-2009 06:23 PM
GM bell housing questions Johnny499 Transmission - Rearend 2 03-17-2008 12:49 AM
426 Hemi Muncie Rock crusher Bell housing 426 Hemi Engine 12 07-26-2006 05:03 AM
