SBC new style crank in old style block - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2006, 02:25 PM
something droll and pithy
I found out the 2 bolt main 1996 pickup block I bought is cracked.
I bought a 3970010 4-bolt main block this weekend at a swap meet and will be taking it to the machine shop to have them check it out.
My question is, if the crank from the 1996 one-piece rear seal block is good, can I use it with the older style 2-piece rear seal block? I don't have both blocks in my garage to compare. If it won't fit right in, is there an adapter?
Old 09-18-2006, 02:32 PM
CNC Blocks Northeast
No that can't be done if you had a eairly crank and a late block that can be done as we build quite a few engines using these later blocks and older cranks but you have to use a speicial rear seal adp. as we use the earlier oil pans.
To bad your combo wasn't the other way around.
Old 09-19-2006, 07:08 AM
Mustangsaly's Avatar
bump ttt
let us know how it turns out..............
Mustangsaly
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Crank Question For My Sbc 67camarokid Engine 20 01-04-2006 05:39 AM
98 Z-28 with old style small block Deeavi Engine 1 11-02-2003 11:41 AM
PCV Valve - SBC - 50's style valve cover spudone Engine 4 10-03-2003 08:22 PM
