Hey everybody I want to know If I Can run a simple plate system to my current setup?? I WANT to spray 150-200 shot
I have a 350 1 piece 87 2 bolt block std deck height 5.7 rods 20over stock crank 20over.. trw .100 dome piston .30 over..
comp cam flat tappet
252 260 @0.50
10:6 comp
Brodix ik200 heads
victor jr intake
JEGS electric fuel pump
fuel cell
750 holley hp jetted 71,80
dynatech headers
msd distributor, 6al, blaster
TH400 BUILT manual valve body
4500 stall
430 gear
28 tire
I know My fuel pump needs to go but what kind??
the rods i have coming eagle i beam forged 5.7
crank is cast will this be okay for one season?
should i sply the block? is it worth the machine work? I want it to be street friendly but can be able to handle the hit
My concerns are the block I have...will it be ok for what im looking to do?
Im yanking the motor soon to change bearings from a wiped cam earlier in the season should i degree my cam? right now its at 0 positon key...Cam card suggest to advance it to 4 degree key..should i do it for nitrous?
Ijust want a good nitrous motor to bring me into the high 9s im
thanks
