Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Nitrous Mustang Fox
Old 12-09-2012, 12:24 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
cjay,how long does it take you to assemble the engine? do you record all clearances?do you custom fit all the parts,ie: file the ring gap? do you measure all the side gaps in the rods,do you fit each piston as exact as possible?
When you take the engine apart,do you compare the wear from the original build specs?
