Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Nitrous Mustang Fox
Old 12-09-2012, 12:37 PM
CJAY CJAY is offline
Originally Posted by vinniekq2 View Post
cjay,how long does it take you to assemble the engine? do you record all clearances?do you custom fit all the parts,ie: file the ring gap? do you measure all the side gaps in the rods,do you fit each piston as exact as possible?
When you take the engine apart,do you compare the wear from the original build specs?
No i didn't get exact with the was my first Re-build of a motor...but i remember the ring gap in the cylinder wall was 18 on the feeler gauge but i didn't check each piston to each cylinder I WANT do ALL for next season..
