Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC OEM Hyd Roller Thrust issues
Old 01-25-2013, 10:22 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by ssmonty View Post
If I were you, I'd remove the retainer plate and inspect the other side where the cam nose contacts, and smooth the surface if its galled. It should show similar evidence of contact if the retainer is acting like the meat in a sandwich. If not, it would suggest that the cam was being pulled rearward by distributor, or pushed from front(wouldn't think so if there is enough timing cover clearance)?
You may want to remove the cam, and install the retainer between the gear and the cam for testing to see if there is adequate clearance. It may not be easy to turn the cam in the block and be certain that any resistance is from the retainer/gear/cam interference alone. Just a thought.
FWIW,
ssmonty
that makes sense. I will pull it apart this weekend and get you some pics of both sides and the cam face and do some measurements and assembly and see what im working with.
