ITS POSSIBLE OIL WON`T COME OUT OF THE ROCKERS IF YOU DIDN`T SOAK THE LIFTERS IN OIL ,BUT IF IT`S SMOKING DRILL MOTORS THERE SHOULD BE GOOD OIL PRESSURE JUST WEAK GAGE AND DRILL.
Normal, lifters don't pump until they are lifting and are properly preloaded.
Good advice from the machinist... Good luck with the fire up!
Outlawed tunes from outlawed pipes |
when breaking in the engine, i was told to baby it
can someone give me a definition of "baby it" ie been told that i shouldn't WOT it at a dead stop trying to break the rear lugs, others told me that i shouldn't bring the engine over 3K rpm who is right? anyone got a good ling to a statinary valve adjustment, i got the order, but it doesn't tell me what to adjust, torque the rocer to ?ft-lbs? till the pushrod can't spin oh please help my nervious butt, its my first engine! Camaro76 |
check www.hotrodders.com/cgibin/ubb/15/001766 or <a href="http://www.hotrodders.com/cgibin/ubb/15/002598]thiS[/URL]
thanks Hotrodders dot com |
Look in the engine forum, there's a few good ways to adjust the rockers/lifters there (type hydraulic lifters or lifter adjusting as keywords). As far as break-in both of the suggestions are good ones. You want to avoid lugging (full throttle starts), and you should watch the RPMs. If you take it on the highway (sustained RPMs), every so often let off the gas and then back on. This will allow the rings/bore to lubricate and seat better (you won't be "burning the bore"). Myself, I beleive once the cam is broke in, so is the motor. However, it's good to be cautious if it's your first motor. I have had freinds that had problems with rings seating from just letting it break-in with the cam break-in like I do. But then again, thier driving habits had alot to do with it. I would have to say there's nothing wrong with being cautious, it's better to be safe than sorry. When you have done a few motors you will better be able to decide how you want to break them in. Go with the ring manufacturers suggestions, as that is the biggest part of break-in apart from the cam. Race motors aren't ran for five hundred miles before a race, but they are put together by pros.
reading over the nice links left by CL(thx BTW) i saw something in there about running the drill for 20min? i ran 2 diffrent drills for less than 5min east and they both smoked, these have yet to fail me befor, and it hard to believe that 2 drills gone bad at the same time.
i also saw priming a fuel system, this is a new idea to me please explain, or show me a link camaro76 [ February 17, 2003: Message edited by: Camaro76 ]</p> |
Not sure but I allways use a gutted distributor.I think theres an oil passage that the distributor housing blocks.If thats true theres were you oil pressure is.
As far as babying it I stay right off them just drive it like its Mom's car.And keep away from high rpms would be my advise. I've got a new heart this year to. So I may put a block of wood under the pedal for the first few miles cause I turn into an idiot sometimes. |
