sbc oil out exhaust - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2011, 04:33 PM
sbc oil out exhaust
i got a 94 z28 with a gen 1 sbc swaped into it i recently just got it tuned in. But its smoking prety bad and theres oil coming out of the exhaust on the drivers side it has true duals so i know which side has the problem im also geting blow by but its out of the valve cover on the passenger side i did a compression chech and and the cylinders all had 90 to 120 psi except for two on the drivers side 3 and 5 they had zero the car hasnt ran since last june but im wondering if im screwed or not any answers would be awesome
Old 03-20-2011, 05:43 PM
DoubleVision's Avatar
If 2 cylinders had zero you got major issues which is likely why it`s doing as it does. It could possibly have holes in the pistons which leads to gas in the oil which makes for a dangerous situation. Pull the dipstick and set a lighter to it, if it flames up quickly you have fuel in the oil. Either way no matter, you may as well pull it, It`s rebuild time.
Old 03-20-2011, 05:47 PM
thanks for the info i prety much figured that was the case i was hoping it wasnt but it happens i have another motor sitting on the stand thankfully but it still blow
Old 03-20-2011, 05:49 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 sounds like re-build time.
Cole
exhaust untchable502 Engine 5 01-10-2008 06:02 PM
Changing exhaust to intake and intake to exhaust? BillyJoe Engine 3 03-28-2006 06:29 AM
Exhaust flow on side exhaust ZeeksChopShop Engine 0 06-03-2004 05:42 PM
Got my exhaust on. Rubberman2003 Hotrodders' Lounge 4 03-02-2004 09:54 AM
exhaust cut-out?? fireforsin Engine 7 03-01-2004 11:35 AM
