Sbc Oil Pan
Hey guys I was just wondering if the small block chevy 400 uses a different oil pan than the other small blocks? The reason I ask is because I have just built a 383 and I need to know if a 350 oil pan will bolt on there clearing the larger throws of the crank.
Thanks in advance, keith
I think not, the 350 pan will be fine, I assume you have a 400 crank in a 350 block. same set up i run , it will hold you in the seat real good ,a blast of a motor to drive. You do know you will need to run the 400 balancer, right? It is externally balanced and heftier then the standard 350 balancer.
Thanks for the info pepi,
I do know about all the clearancing issues and such if I used a stock GM 400 crank but I bought the entire rotating 383 Scat assembly internally balanced (cost me a pretty penny) so I am set with the stock 350 flywheel (but we all like aftermarket lightweight flywheels as well )My main concern is the issue of the oil pan because that is the next expense on my list and I want to make sure I can use a standard SBC oil pan and it will clear the crank. Thanks again for your reply I really appreciate it! Speed Kills, Do your part, DRIVE SLOW, Drive a mustang.
My stock oil pan rubbed the crank on my 383 just enough to wear out a spot weld that holds the baffle I did not know it was rubbing and once it let go it made an awful sound when running. but luckily it did not hurt anything. maybe I used the thin gasket that vega is talking about?
I am looking at the 7 quart deep sump chrome oil pans. They are advertised for a SBC so with all of this info I will assume it will match up
Thanks Guys. |
The pan on my 383 had to "clearanced" along the side rails. Just a slight adjustment. I would check while the block is on the stand. I didn't find out until the engine was in.
1955-74' are thin gaskets and 75'-85' are thick but most people use the new one piece anyway.one way to tell if in doubt is,,if a .006"-.010" feeler guage will fit between timing chain cover and oil pan,,you need the thick seal.the pans are the same.
I think the pan you are planning to use should work fine, but as someone else said, check it as the engine goes together. Regarding the thick/thin gasket I thought that was just the thickness of the front oil seal portion of the gasket???? I also thought that about 99.9% of new aftermarket pans were designed for the thicker front seal . . . . But, maybe I've been halucinating. Some aftermarket Chev pans, particularly the ones made of cast aluminum, present problems for the 383 conversion, but you said you were looking at 7 Qt chrome. FYI -- I strongly recommend something like a Milodon, or other name brand. I bought Tiawanese the first time (with the matching pickup) and there was insufficient side cleance between the pan and the pickup. Couldn't get the pan bolts in the holes. I could have solved the problem with a die grinder inside the pan (cutting away flashing) but then I'd need to find a way to get it 100% clean. That seemed impossible with all the dust traps that were there. So Milodon finally got my money anyway.
Pat |
Thanks for all the help guys!
cheers, Keith |
| One piece sbc oil pan gasket? | jtybt | Engine | 1 | 04-26-2006 05:33 AM |
| 8BA flathead oil pan cleanout plate | powerrodsmike | Engine | 0 | 09-13-2005 04:52 AM |
| oil pan baffle | squids1 | Engine | 3 | 08-21-2005 05:42 AM |
| SBC Oil Pressure Problem....!!?? | chevyelc81 | Engine | 8 | 07-25-2005 03:40 PM |
| Milodon oil pan...7 qt w/ filter or + filter? | Finmike | Engine | 6 | 07-05-2004 10:44 PM |
