SBC oil pan/ gasket differences - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2007, 04:16 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
When comparing one-piece rear SBCs, are vortec pans/gaskets interchangeable with non vortec? Can I use an 87-96 pan/gasket on a 96-later vortec engine?
Some gaskets list as fitting 87 and later one-piece engines, while others only list 87-96. Same with pans. Straight dope anyone?
Old 02-08-2007, 04:25 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
There is a difference on some year models....what side the dip stick is on.
Old 02-09-2007, 06:18 AM
bondo's Avatar
Ayuh,......
I think the Dipstick swapped sides in 1979,.....
The Block didn't change with the Intro of the Vortec heads in 1996.......
Sooo,..... The Gaskets should be the Same from 1987 On......
Old 02-09-2007, 06:25 AM
GMC boogie's Avatar
The Vortec SB V8 pans are interchangeable with the earlier 1pc seal engines. The gasket is made a little different for the Vortec due to the plastic timing cover. Simply get a pan gasket for whichever cover you are using.
Old 02-11-2007, 10:18 AM
fast68's Avatar
likes chevy trucks & boobies
it was 80 that the stick moved, not 79
and the one piece RMS was in 86, not 87
therefore the pan gaskets go from 55-79
and 80-85
and then 86-95
not rocket science here
Old 02-11-2007, 11:35 AM
curtis73's Avatar
Wiki Edits: 16
Ok, great. I'm winning a 1-piece cast aluminum marine oil pan on ebay for $20 brand new. That will look great polished up on my boat.
Off to buy gaskets for a 96-later 1-piece.
Old 02-11-2007, 12:38 PM
junior stocker's Avatar
Fast 68, Let's remember the 55 blocks did not have oil filters cast into the block and the pan was different; therefore the gaskets are different. But, the "correct" amount of gaskets do come in the set to cover those blocks usually. Just a "technicality". BUTCH.
Sbc 400 Oil Pan weedhopper Engine 7 06-18-2006 08:23 PM
One piece sbc oil pan gasket? jtybt Engine 1 04-26-2006 05:33 AM
Excessive oil under valve covers in SBC? TVR383 Engine 13 11-21-2005 12:48 AM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
1 Piece Oil Pan Gasket Advise 69 Camaro daveh Engine 7 04-14-2004 03:12 PM
