SBC oil pan question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2006, 11:28 AM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
I got a customer's boat in the shop that Im working on right now.
Im putting a 400 togather to replace the beaten down 350 that was in it, and Im using as many parts as I can off of the 350.
Ive heard the oil pans are notched on the 400's for clearence. Where exactly are the notches and how much so I can modify the 350 oil pan to fit on the 400 since it is a higher capacity oil pan.
Brad
Old 06-25-2006, 11:56 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
The rod nuts may hit the pan along the block. I have used that pan on 400 or 350 were you put in a stroker. When you are building the engine, turn the engine over several times with the pan on and no gasket and see were it hits and work it over a little with a small ball peen hammer. Not all of the pans will hit.
Old 06-25-2006, 06:13 PM
Gone fishin'
Wiki Edits: 2
Alright I wasn't for sure or not on this, and just wanted to make sure.
I put cleaned the pan and put it on the block and bolted it on without a gasket, and turned the crank by hand several times. No rubbing or anything, so I guess I don't have to change anything then.
Thanks
Brad
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 06:14 AM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
can the wrong oil pan make this sbc leak? bigwildgrin Engine 10 12-19-2005 06:33 PM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
SBC Moroso Oil Pan Rad Ray Engine 2 12-25-2002 03:50 PM
