SBC oil pan removal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2008, 07:12 AM
v8hed's Avatar
AK427
Have removed all bolts except a couple on the passenger side rear as the starter is in the way (I only need to lower the front of the pan). Despite 90% of the bolts being out, the pan won't budge (even with some screwdriver 'encouragement').
Suggestions?
Thanks,
Ian.
Old 06-30-2008, 09:39 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
It is pretty amazing how "stuck" these can be depending on how much silicone the previouse owner used. Plus you have the timing cover overlapping. If you have removed the timing cover bolts already then I would say just give the cover a yank and it should all loosen up.
Old 06-30-2008, 09:48 AM
Jmark's Avatar
If you are trying to pry it loose, then just bolt it back up, it won't work. If it's stuck that hard, the gasket will rip in numerous places. Pull the starter and remove all the bolts and pull it all the way off. Clean it all and use a new gasket.
Old 06-30-2008, 09:53 AM
v8hed's Avatar
AK427
Thanks guys. The whole reason I wanted to drop the pan was to get the timing cover off. However, when I was under the car trying to get the pan off, the timing cover suddenly just popped off (I'd taken all the bolts out already) and nearly smacked me in the face! I still want to drop the pan so I can check the contents for anything undesirable and to change the gasket just for 'belt and braces'.
Old 06-30-2008, 11:19 AM
302 Z28's Avatar
Reminds me of the time I was working as a dealership mechanic. I had a comback on a new hire mechanic who had been let go previously. He installed a rebuilt shortblock in a car and the engine had gone south. I pulled the engine and strarted taking it apart. This moron had used several tubes of 3M "yellow snot" weatherstrip adhesive on everything. The oil pan gasket had it on both sides very liberally, the timing chain cover, the intake, and the valve covers. I actually had to chisle the oil pan and the valve covers off, which made it impossible to reuse them. The shop foreman took pictures of the mess and posted them on the shop bulletine board and dared anyone to use the stuff on an engine or risk being fired.
Vince
Old 06-30-2008, 01:59 PM
I think he switched to RTV
Old 07-04-2008, 08:01 AM
Vince
Didn't leak though, did it?
I use the stuff for certain things, but not on something I think might need to be taken apart in the next several years.
Old 07-04-2008, 10:40 AM
Hmm, Ive always found the gorilla snot to come off rather easily. Its the dark permatex "form a gasket" stuff that I dread finding on my gaskets. Wow!!
Give that oil pan a few solid raps on the bottom edge with a rubber mallet while your prying and always be carefull not to disfigure it with your prybar. That is a surefire way to cause future leaks.
Old 07-04-2008, 03:00 PM
Ah yes, Permatex Aviation Form-A-Gasket.
I always thought it was designed to allow the airplane engine to keep running in case all the bolts fell out. Itsa safety thing. LOL
Actually it is the only way to stop the leaks on a radial engine.
Old 07-04-2008, 03:21 PM
Gasoline will soften dried yellow 3M, but you may have to soak it for a while.
Permatex #2 will soften with alcohol, the more concentrated, the better. This also can take a while.
Stuff sealed with Permatex #3 generally peels off easily, and what residue sticks to the metal also cleans up with alcohol.
Old 07-04-2008, 04:16 PM
Gasoline will soften dried yellow 3M, but you may have to soak it for a while. Permatex #2 will soften with alcohol, the more concentrated, the better. This also can take a while. Stuff sealed with Permatex #3 generally peels off easily, and what residue sticks to the metal also cleans up with alcohol.
Not with Permatex Aviation Form-A-Gasket #80019
RTV
Old 07-08-2008, 11:02 PM
RTV
That's the stuff. I've been using it for ~35 years. I paint it on the gasket and let it sit for a few minutes so it can soak in some, then paint it again just before installing. It turns loose pretty easily that way, and many times the gasket can actually be reused with another light slathering.
And I agree wholeheartedly about RTV. It has a couple of good uses, but mostly it's a pain in the backside.
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 08:39 AM
Replacing Oil Pan Gasket on 1972 Nova 454 With Motor In Car - Help leejoy Engine 17 04-28-2008 02:58 PM
Sbc 400 Oil Pan weedhopper Engine 7 06-18-2006 09:23 PM
7qt Oil Pan & Pickup SBC Small Block Chevy Mustangsaly Engine 6 06-12-2005 08:52 PM
Oil Pan Removal sb72elcamino350 Engine 1 01-17-2004 04:35 PM
