Sbc Oil Pressure - How Much Is 2 Much? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-13-2004, 08:37 PM
69elcaminoss's Avatar
Try a thicker viscosity oil???
  #17 (permalink)
Old 04-13-2004, 08:50 PM
46_stvblt's Avatar
Back in the day, If we were pumping too much oil up to the top end , we'd put pipe stem cleaners in the push rods to limit the oil coming thru them. It works and its cheap....GlennK
  #18 (permalink)
Old 04-13-2004, 09:17 PM
Jmark's Avatar
Oh My Gosh!!! More pipe cleaners!!! LOL ( its a long story, offense meant) Sorry!! that was supposed to say "NO offence meant"!!
Mark
  #19 (permalink)
Old 04-13-2004, 09:53 PM
johnsongrass1's Avatar
Race it, Don't rice it!
My idle pressure @ 850rpm hot is around about 25-30psi. What sort of other damage could excessive oil pressure cause? I was told by some that if there's lots of oil in the top end of the engine, then there's problems with lubrication down low.
Don't confuse oil pressure with oil volume. Pressure comes from a restriction and it doesn't affect volume. If the volume were to much and the oil is uncontroled then you could get too much oil in the heads and eventually run out of oil in the pan. If you have a high restriction this is a good thing. It means the tolerances are still close. If you have volume to compensate, oil pressure will remain high even though tolerances ar bigger than spec. It 's a cheap way of compensating for worn out engine bearings. I would recommend you change pumps or relief springs with 90 pounds at RPM. Your just overheating the oil and it's costing you power. As much as 15 horse in some cases.
  #20 (permalink)
Old 04-14-2004, 06:50 AM
Re: Sbc Oil Pressure - How Much Is 2 Much?
Originally posted by HJCHEVY400
I have a 350 bored .040", mellings high volume pump. When Cold, if revved a little near 2500rpm-3000rpm, oil pressure gets to 90psi. When hot, maximum at full throttle is around 78 psi. Guage used to check this is an Autometer.
Is this too much? Can it cause damage to anything?
I am the last to day I know a lot about engines just listen and been learning. But mabe a mechanical gage to check the pressure if the one you are using is electric. Ed ke6bnl
  #21 (permalink)
Old 04-14-2004, 09:57 AM
HJCHEVY400's Avatar
When Cool Meant Cubic Inches
I tried using both types of guages, but without a different result between the two, So I just keep using my current Autometer, which is mechanical.
  #22 (permalink)
Old 04-15-2004, 09:48 PM
snod83's Avatar
If you are worrying about too much oil to the topend, grab a set of roller rockers, which have a much smaller oilling hole and will lower the amount of oil to the topend.
  #23 (permalink)
Old 04-16-2004, 08:29 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
pipe cleaners
46_stvblt
Welcome to the ...over-the-hill-hack...club.lol
Troy
_______
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
  #24 (permalink)
Old 04-16-2004, 12:50 PM
46_stvblt's Avatar
Troy- Thanks..I guess getting old kinda sucks...No respect...How in the world did we ever survive.......GlennK
  #25 (permalink)
Old 04-16-2004, 02:50 PM
troy-curt's Avatar
Respecting my elders and commonsense.
Troy
_______
