SBC oil valley plug question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2009, 09:27 AM
When you are running a solid lifter cam. Do you remove any of the oil valley plugs at the front of the block above the timing chain cover? Just wondering what the thoughts are on this topic across forum.
Old 07-12-2009, 12:55 PM
No, always make sure they are in place.
sam-missle
Old 07-12-2009, 01:08 PM
I think massive oil leak = no oil pressure
Old 07-12-2009, 01:39 PM
The plugs are on the inside of the timing chain cover it would result in more oil getting back in the pan quicker.
Old 07-12-2009, 01:40 PM
I never have done just heard of someone doing it an was wondering what this forum thought of the idea.
Old 07-12-2009, 06:27 PM
Overdriv's Avatar
Are we talking about a small block Chevy. What plugs above the timing cover??
Old 07-12-2009, 06:34 PM
ericnova72's Avatar
More for Less Racer
For the SBC, the only plugs under the timing cover are at the end of pressure galleries fed by the oil pump. Remove them and you will have little to no oil pressure feeding ANYTHING in the engine. Maybe you are mis-understanding what the are telling you??
Old 07-13-2009, 12:47 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sometimes an engine w/a solid or roller cam along w/roller rockers will use oil restrictors in the oil gallery. This is prob. what you are referring to.
On a Chevy the ones that are easiest to use, are located at the rear of the engine (bellhousing area). There are other styles of restrictors as well- in fact some will say to not use restrictors, period- regardless of what type of lifters or rockers are being used.
My thoughts are that the intended use and RPM level and duration of this level has a lot to do w/the choices made. A street or dual use engine does not need them, IMO.
Old 07-13-2009, 12:58 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Some fellows will replace one of the solid front plugs with a plug which has had a 0.030" hole drilled in it to supply additional oil to the timing chain or gear.
Old 07-13-2009, 08:38 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The "trick" way to do the oil galley plug to oil the timing set, is to use a drilled, threaded plug instead of the cup-type plugs.
Pontiac's use the drilled plugs stock and are included in their welch plug sets, at least in the 400 and 455 sets. This requires tapping the galley for the threaded plug, but a lot of builders do this anyway.
Another modification that's also basically unnecessary is drilling into the thrust face of the cam's timing gear to intersect w/the oil passage. It'll oil the thrust surface, alright.
Old 07-13-2009, 10:33 AM
No, this would result in a pressure leak to the pan with a large, if not complete, loss of pressure in the lubrication system.
There are reams of pages written about shutting off the lifter oil supply when converter a block from hydraulic to solid lifters. Frankly, I think this is an exercise in a fantasy that accomplishes nothing meaningful and with some engines, the Chevy's a case in point, can be downright fatal to the valve train.
Leaving pressure oil in the lifter galleys when running solids only saves for the engine that oil which leaks around the lifter through its bore clearance, not very much in oil the big scheme of things.
Additionally, the Chevy in particular uses oil passing thru the lifter, whether that lifter is a solid or hydraulic, to furnish lubrication to and thru the push rod to the rocker and spring. This oil also serves to cool the spring, which is an extremely important function necessary to avoid loss of tension and/or breakage of the spring. Full up race engine builders that cut off the OEM oil supply from the lifters to the overhead, must, and do, build an external oil supply to the rocker box to replace GM's normal oil routing that has been terminated. If you're building a serious race engine, especially one using a dry sump, this technique of rocker-box oiling has some advantages of being able to put oil exactly where its needed and in proper quantities. For anything less this is an exercise and expense with not enough return as the stock system is quite adequate for anything short of NASCAR long distance races.
So my advice is this:
- First you need to be sure your feeding oil to the upper push rod end, the rocker trunnion, especially if it's the OEM ball and socket type, rollers are tolerant of much less lube, unless theyre Chinese made knock-offs in which case keep 'em really oil wetted, lastly oil to the valve and spring assembly. Oil to the valve and spring assembly lubricates the valve stem and guide, lubricates the ends of the spring where it is riding on the head and the retainer and the oil provides cooling to the spring.
- Second is then either selecting lifters that feed oil to the pushrod for delivery to the rocker box, or if selecting a non-feeding lifter, purchasing or fabricating an externally mounted lubrication system into the rocker boxes to provide for the needs of lubricating and cooling the components contained there-in.
Bogie
Old 07-13-2009, 06:08 PM
These post confirmed why I have never done anything to the plugs. Thanks for your opinions.
Low oil pressure on SBC lg1969 Engine 4 08-07-2010 01:45 PM
Spark Plug brands question Francis Engine 65 07-15-2008 12:01 AM
another oil pressure question timemachine Engine 2 09-26-2007 09:26 PM
Oil pump question 92 sbc Eric64 Engine 3 06-07-2007 05:14 PM
Valce cover Oil leak problem / PCV system question hotrodf1 Engine 7 05-01-2007 02:44 PM
