[sbc] options for alternator w/ short wp and headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2007, 09:54 PM
Hey guys, im just looking for options for alternator setup on an sbc w/ headers and short water pump. Right now im using a funky mr.gasket setup where a bracket mounts over the drivers side header using the header bolts... but it's proved to be pretty flimsy and last time I was at the track I lost a belt. It's kind if a long belt setup and has flext with motor rpms.
Anyways, I was just wondering what sort of other options are out there as far as bracket systems go. If anyone can point me towards a company who makes good alternatives or has pictures that would be great.
Thanks,
Kevin
Old 03-29-2007, 12:03 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You could try Zoops.
http://www.zoops.com/main-brackets.asp
Old 03-29-2007, 04:30 AM
Here is a very good article on your problem;
http://www.chevyhiperformance.com/te...leys_brackets/
And try this site for brackets;
http://www.alangrovecomponents.com/
Old 03-29-2007, 04:35 AM
poncho62's Avatar
Wiki Edits: 5
Jeese Louise..Why do people insist on spending a ton of money on a simple fix........................
I took an old alternator adjustment bracket, cut and redrilled it and put it to the bottom bolt of the alternator. That strengthens it a lot........
Not a great pic, but you can see it here.
Name:	Copy of pontiac 007.jpg
