SBC Pilot Bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2007, 08:00 AM
Brian's56Chevy's Avatar
Last journal entry: Spring is coming
SBC Pilot Bearing
Guys, on my project I am installing a 3 speed transmission onto a former powerglide equipped 283 ('67). I purchased a clutch kit that included the pilot bearing (Bronze) and it is just a weeeee bit too big. I have a 327 block that the bearing fits into w/o issue. Is there a difference, do I have a wrong bearing, does this one need to be machined to fit the 283? Can you give me some possibilities. As an FYI, the throwout bearing that came in this kit broke 2 mins after I had it out of the box (bought new one made in USA), so this is why I suspect it may be the bearing as opposed to the motor, but this being my first go at this - I don't know. Any help is appreciated! Thanks, Brian
Old 07-04-2007, 08:23 AM
I think I have found the issue as I researched on the Dorman site. The bearing I need is about .033" smaller (in my previous post this would constitute: weeee). My only question now is, what is the difference in "Clutch-In!" and not?
Pilot Bearing / Solid or ballbearing type"whats best to use" x711 Transmission - Rearend 16 01-10-2007 08:03 AM
Pilot Bearing Problem shad88 Transmission - Rearend 4 11-01-2006 09:26 AM
400 sbc block 350 crank bearing spacers. 406 ss monte Engine 2 05-30-2006 05:38 PM
Rear main bearing cap question...SBC bennett Engine 1 06-20-2004 01:24 PM
Stuck pilot bearing in 350 sbc I got it! zachscc Engine 3 12-23-2002 05:48 AM
