-   -   sbc pinging (http://www.hotrodders.com/forum/sbc-pinging-223748.html)
sbnova 09-06-2012 06:58 AM
sbc pinging
HI my sbc 350/400 hp has a pinging problem. I currently have a mallory unilite distributor with vacum advance. I tried setting my total timing at 33,34,35 degrees and it did not help. I went back to base timing of 6,8, and 10 degrees and no change. The fuel has been changed to fresh 93 octane tried octane boost no good, I am thinking distributor I am currently trying the vacum advance adjustment by turning the allan key in the vacum advance canister counter clockwise to reduce the advance curve so far ng. does anyone have any suggestions? can the distributor be defective? should I try another maybe msd or pertronix? thanks for any help..
SSedan64 09-06-2012 07:59 AM
More Info needed, as much as possible:
Heads?
Compression?
Pistons?
67Mustang Al. 09-06-2012 08:17 AM
AS ss said. Your compression ratio is the dictator for octane rating of the fuel required. You may need to up the octane to around 98+ and alter the ignition timing back until it stops pinging.
We ran 13 to 1 compression in a stroked BMW using ethanol and wrecked a set of JE pistons .
I may be wrong but i think 10.5 to 1 is the limit for 93 octane fuel.
Al
sbnova 09-06-2012 10:07 AM
I have 10-1 compression, stock heads, holley 750 dp, 514 lift cam.
68NovaSS 09-06-2012 02:49 PM
If you would do a search here, there are literally hundreds of threads in the database about timing, pinging, causes and cures.
bigblockragtop 09-08-2012 09:45 PM
Take it around the block w/o vac advance hooked up and see if that works. Are you sure counter clockwise is for less vac adv?
sbnova 09-09-2012 06:21 PM
I was told so by mallory counterclockwise lessens the advance. I am still adjusting 1/4 turn at a time to see if it lessens. I am also going to re jet my holley up 3 size jets as the plugs are reading too lean which can also contribute to the pinging.
bigblockragtop 09-09-2012 06:22 PM
Ok Most would recommend one change at a time. Good luck!
sbnova 09-10-2012 06:54 AM
Thanks but I am totally frustrated. Just unloaded , will try one at a time...
cobalt327 09-10-2012 10:52 AM
There were three different timing tab/damper TDC line combinations used on the Gen 1 SBC (not counting the plastic timing cover engines like the L31 Vortec, etc.). Mixing/matching the tabs and dampers can cause a false reading when you go to time it. More on the differences HERE.
Some info on setting up a timing curve is HERE.
Other possible causes for preignition is a hot spot in one or more cylinders. This can be a sharp edge left over from having the heads decked, or a bit of casting flash.
Be sure the spark plug heat range is not too hot. Obviously, vacuum leaks can dilute and lean the air/fuel mixture and that can add to being detonation prone. So be sure there are no leaks. You can remove all the hoses except for the vacuum advance and plug the ports to eliminate vacuum leaks coming from the vacuum accessories. Be sure there are no leaking intake or carb gaskets and that the PCV system is working as it should.
Check the color of the spark plugs to be sure the air/fuel ratio is not overly lean. Be sure the float level is right, fuel pressure adaquate (about 5 psi) and the filters are flowing properly (if in doubt, replace).
Another area to look at is the dynamic compression ratio (DCR). If the cam is very mild and the static compression ratio (SCR) is too high, the DCR will also be too high for pump gas in some cases.
THIS is one of the CR calculators that are online. Plug your numbers in and see what you get.
To see what the dynamic compression ratio is you need to know the rod length (stock is 5.7") and the intake closing point of the camshaft. This lets you estimate whether a combination of parts will be able to use pump gas w/o detonation, for example.
A couple calculators for dynamic compression ratio:
Dynamic CR
Another dynamic compression ratio calculator
Here is a short page on the compatibility of different cam durations to the compression ratio.
One last thing- do yourself a favor and read up on "quench". It's an important part of the engine build and can make the difference in having an octane hungry pinging engine or a smooth running engine w/o detonation.
Good luck.
sbnova 09-10-2012 04:57 PM
Thank you will grt the figures.
