Hotrodders Bulletin Board
#1
SBC pulled motor with torque converter attached
Allright, so I'm replacing the leaky oil pan gasket in my Chevelle. I just swapped in a 1997 Silverado with the one piece gasket and the crappy thing leaks....so I had to pull the motor again (long story with why the gasket leaks...I'm not buying that brand again.)
Anyway, in my excitement I forgot to disconnect the flexplate from the torque converter (TH350)! When I got the thing separated, there was the converter (and a bunch of tranny fluid on the floor). Is it okay to just replace it like that? The front seal on the tranny looks fine. Thanks! |
#2
I would seperate the converter from the plate, go ahead and replace the front seal while i was there easy and cheap to do place the converter back in the trans and make sure it sits back in place. You do know to spin the converter while pushing on it till it drops in place, you cant do this with it on the plate thats why you need to place the converter back in the trans. And then install the motor back after you get done with your oil pan gasket. JMO. Cole |
#4
No problem, good luck with it.
#5
Just remember this. When the torque converter is seated all the way in, you cannot get your fingers between it and the top of the bell housing.
#7
It does not matter, just lift it up while turning, and pushing it back in. Once it seats the final way in you will know it. |
#8
Yes, and you should be able to move the converter when the trans is bolted to the engine. Learned that the hard way.
#9
When you push the converter back onto the shaft and have it seated, go ahead and give it another push! In the past I have thought I had it seated properly & then found it would go on another 1/2 inch before seated properly.
#10
As long as the torque converter has to come forward to meet the flexplate when you install it, it is installed properly. If you go to install it and find that the torque converter hits the flexplate before the tranny and engine are seated, you need to go one more "clunk" with the converter.
I highly doubt you damaged the front seal, but its so easy and cheap to replace that I would go ahead and do it. The 1% chance that you damaged it is outweighed by the 99% pain of disassembling it a second time to fix it But definitely undo the TC and put it in the tranny before you reinstall. Much easier that way. |
#12
We installed the tranny and crossed our fingers |
#13
the converter needs to make 3 "clunks" before it engages properly, first the pump tabs, second the stator's splines and third the input shaft's splines, and yes you won't be able to fit your hand behind it when properly installed.
replace the seal, not worth the chance. |
#14
OP prob. already knows this- but don't be tempted to pull the tranny up to the block by using the bolts. Bring the two together first- before tightening the fasteners!
Back to top |
Similar Threads for: "SBC pulled motor with torque converter attached"
| Torque Converter play | 70bird | Transmission - Rearend | 2 | 03-29-2007 07:23 PM |
| Torque converter question(s) | chrisflock | Transmission - Rearend | 3 | 11-10-2006 11:41 AM |
| Building a SBC to rev to 8k, and have power | Andyrew | Engine | 52 | 04-17-2006 12:46 PM |
| Torque converter, diesel vs gas | pjd | Transmission - Rearend | 4 | 09-10-2005 08:52 PM |
| Torque Converter Problem? | 38project | Transmission - Rearend | 5 | 06-05-2005 02:21 AM |
