sbc pulleys swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2010, 09:00 AM
sbc small damper pulley confused?
i picked up a 4 bolt main motor out of a 68 chevy truck that is in great condition even after i tore it down the insides were super clean. there are two questions i have. the damper pulley on the motor is a lot smaller than the damper pulleys on other 350s i dont know if it was changed out and if it was why would it be smaller. and i have ran the numbers on the motor it is a 350 plus its a 4 bolt main. the other question i ahve is is there anywhere where i can get a diagram for the pulley bc the motor has none and i want to make sure i put the right ones on the right way.
Old 09-21-2010, 11:41 AM
bubbahotep's Avatar
They do make aftermarket undersized crank pulleys for less drag on the crank in hopes of gaining horsepower. A smaller pulley can turn the other pulleys easier but it also drops the speed that all the other pulleys spin at.
Old 09-21-2010, 01:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You need to decide on whether you are going to use the "short" or "long" water pump set-up. They use different pulleys and brackets as well as different w/p.
DRAWINGS OF SHORT AND LONG PUMP
You can also use an OEM or aftermarket serpentine set-up, the w/p for that is reverse rotation, long style.
March, Jegs, Summit and others all sell pulleys but I would say to find what you need from the junkyard. Get ALL the pulleys, brackets, etc. from the SAME vehicle, and make note of what that vehicle make, model and year is, so you can get belts, etc. for it.
Old 09-21-2010, 06:03 PM
ericnova72's Avatar
More for Less Racer
There are also differences in crank pulley diameter due to performance(hp) level and rear axle gearing. Vehicles with deep rear axle gears 3.42/3.73/3.90/4.11 got smaller diameter crank pulleys to avoid overspeeding the accessories. Cars with lousy rear gears 2.41/2.56/2.73/3.08 got larger diameter crank pulley to make sure accessory speed will be high enough to avoid slow water flow(overheating) and low alternator output.
Old 09-21-2010, 08:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Oddly enough, 90 V6 Chevy 200cid and 229cid engines got underdriven crank and w/p pulleys- w/2.29:1 rear gears and AC.
The little V6 engines don't have any problems cooling, and a small alternator pulley takes care of charging.
I have used these pulley sets and just the smaller crank pulley on SBC engines through the years, but nowadays, finding a 90 V6 other than a 4.3L is all but impossible. But if you run across a set, grab them.
Old 09-22-2010, 10:48 AM
sbc pulleys swap?
i pulled my motor out of a 68 chevy truck but the only thing it has i sthe damper pulley. i was wandering if i could pull a set up off a 1980 chevy pick and place it on this motor replacing the damper pulley and everything take it complete from the 1980 chevy motor 350 and putting it on my 350. also if it was a 305 would it still work? just trying to save myself a little work from locating all the pulleys and getting them set up right i would rather just pull it off one motor and set it up on the other thanks for the help.
Old 09-22-2010, 10:59 AM
ericnova72's Avatar
More for Less Racer
Yes as long as you use the longer 69-up water pump that goes with the pulleys. You can't use the short 68-earlier pump with the later pulleys, things won't line up. Use the '80 powersteering brackets(if you need them) and alternator brackets also. 305 stuff is the same as 350.
Old 09-22-2010, 11:04 AM
great thanks youve been a big help and time saver i love this forum
Pulleys Don't Line Up Sbc, Pics, Help!! sexypizzaman Engine 46 02-21-2008 05:18 PM
sbc 4-7 swap cams 406 ss monte Engine 2 05-08-2007 10:46 PM
SBC 283 intake & Carb Swap Problems iceman_77 Engine 4 02-13-2007 06:49 PM
eaton m112 blower sbc manifold? oklowride Engine 3 12-25-2006 02:21 AM
4.3 to SBC swap in an S-15 adryan16 Engine 1 12-30-2003 08:52 AM
