SBC Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2009, 06:14 PM
SBC Question
situation: a 350 block minus heads and intake
Can I throw 305 heads and intake on top of this block? What's the drawbacks of using heads from a 305 on a 350 block?
thanks
Old 07-29-2009, 07:19 PM
DoubleVision's Avatar
If this is just a daily driver without performance in mind the only draw back is the compression ratio that will result in using a small chambered 305 head. The small 58cc chambers raise the compression ratio considerably on a 350 and that could cause detonation and that can kill your engine. If your 350 is a stock 350 with dished pistons you can install the 305 heads and carefully set the timing curve and run premium fuel and get away with it. Also a help would be to run a cooler T stat such as a 180 degree as well as cold air induction. If your engine is overbored with flat top pistons it`s likely the ratio will be too high for pump gas.
Old 07-29-2009, 07:45 PM
thanks
(BIG BABY) There will be no draw backs just make sure you change the valve seals and use your 305 exhuast manifold for better flow.
Old 07-29-2009, 07:52 PM
techinspector1's Avatar
Wiki Edits: 326
aormz, if I were you, I'd pay attention to what DoubleVision says. He's been there, done that a few times.....
New SBC 383 build question + parts list Filmjay Engine 40 04-25-2010 09:25 PM
SBC cam thrust plate question techron Engine 3 02-28-2009 04:07 PM
Dual AFB carbs on SBC, question 04SilveradoMykk Engine 10 12-07-2008 01:02 PM
SBC Valve Cover Question Jag Daddy Engine 4 10-31-2003 05:03 PM
