Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc question
Thread: sbc question
Old 02-22-2003, 07:56 AM
kellogs's Avatar
kellogs kellogs is offline
Post
when it runs again check to see if you have a small exhaust leak.as for the smoking a new motor will do that until everything seats properly.did you redo the heads also?may need valve seals.if the plugs are gas fouled then the carb may need rebuilding or the choke could be stuck.if it ran once but ticked you shouldn't have much trouble getting it restarted.
