sbc race starter question... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2010, 09:09 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok so I recently put on a race car starter on my 83 monte carlo.I belive in the directions it said to not crank it over more than once every two minutes...does that sound right?also why so?also lastnite I noticed one of the wires coming up through the tube to the starter had melted&then it wouldnt start.I'm hoping maybe I just left a nut kinda loose...but could it be cranking it over more than once every few minutes??????
Old 03-04-2010, 06:51 AM
did you get them wires replaced ?
them little starters require a lot of amps , two minutes is to long if you ask me .
why it not starting right up ?
fuel issue , loosing the prime in carb and fuel to pump .
my olds are like that till i put a longer fuel line before the fuel pump .
made a long bend dropping line 6-8 inches below the pump keeps the gas from siphoning back to tank every time , 2 days of sitting would leave me nearly draining the battery .
i had to open hood and prime the carb every time i wanted to drive it , didn't want a electric pump .
Old 03-04-2010, 10:06 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi kid,
In the instructions didn't it read engage the starter for 15-20 seconds, & then let it cool for two minutes before trying again?
even if it didn't read quite that way, that's what they meant.
witch wires melted, the large one from the battery, or the fusible link wires, or all of them?
Rich
Old 03-04-2010, 10:09 AM
two cups of tea
Wiki Edits: 2
I think it was the fuseable link one
Old 03-04-2010, 10:30 AM
two cups of tea
Wiki Edits: 2
What woild of caused ghe fuseable link to go out?
Old 03-04-2010, 10:48 AM
for the links to melt you either have a defective solenoid, a bad ignition switch, or a short in the wire, If I were fixing this I would put a ford solenoid on & replace whatever wires need replacing. Good luck,
Rich
starter motor question chevy1500z71 Engine 4 04-19-2009 07:26 AM
sbc chevy starter question illegal regal Engine 6 01-23-2009 09:50 PM
350 SBC Block Damage from Starter twinksta Engine 7 09-23-2008 05:21 PM
starter question Dubz Engine 4 05-02-2004 06:00 PM
