SBC "Rams Horn" Manifold Bolts- Size?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2005, 06:33 PM
acr acr is offline
Can someone tell me the bolt size, thread, & length of SBC Rams Horn exhaust manifold bolts?
Old 03-30-2005, 07:32 PM
The threads are 3/8 16 and the lenghts are different........some of them require longer bolts in the middle two.
I just get mine about 3/8 to 1/2 longer than what the width of the manifold is......
Old 03-30-2005, 07:41 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
bolts
Be sure to use a #8 bolt or they will break. Antiseize on the threads will make them easier to remove later.
Old 03-30-2005, 07:57 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
just go grab a handful of standard thread bolts at the hardware store, 3/8ths size. You can measure the depth of the manifold if you need an idea.
K
Old 03-30-2005, 08:49 PM
acr acr is offline
Thanks Guy's ! acr
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
Intake Manifold Bolts - Need Sleeves?? jerseyjeff Engine 5 11-18-2003 01:00 PM
Torque spec for intake manifold bolts jpd37 Engine 3 09-17-2003 10:31 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
SBC head bolts fred56 Engine 2 03-27-2003 10:44 AM
