SBC Rear Main Seal - Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2007, 03:37 PM
Just fired my 350 yesterday and after running it for a half hour noticed that the rear main is leaking. Fired it up today to make sure I wasn't dreaming, once it's warm at about 2500rpm I would get about 1 drip per second - pulled the engine out and have it apart - need to buy some parts, what do you suggest?
The rear main seal I installed was the same brand I ran last year without any problems - just a blue Mr. Gasket 2 piece that came as part of the complete gasket kit. I installed this one the same way, had just a bit of rtv between the two halves, and it leaks. Inspecting closely on one face of the upper half I can see where it is cut just a little - I wonder if somehow I pinched it installing the cap and tore just a bit? Anyways - is the Felpro 2900 what I want or is their something better out there? I can see a faint line on the crank from wear - should I install an offset lip seal just to be safe? It looks like all of the offset lip ones I find are just rubber and not silicone? Any suggestions would be greatly appreciated!
Old 03-11-2007, 04:25 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I'd do the offset. Crank surface is most important.
Old 03-11-2007, 04:37 PM
Will a rubber one hold up ok instead of silicone?
Old 03-11-2007, 04:52 PM
Also - how hard is a rubber one? Reason I ask: crankshaft is still in the block - I know I can slip a silicone one around the crank, it's pretty stout - is the rubber one the same consistency or soft? Thanks for the help!
Old 03-11-2007, 07:00 PM
302 Z28's Avatar
The hard rubber ones will also slip around the crank, done it quite a few times.
Vince
Old 02-15-2011, 12:19 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Just a note I know this is an old thread, But I too have just been burned by a fell pro 2900 rear main. Installed while the engine was out, Crack surface was fine, had to pull the pan in the truck, and Installing a fel pro BS118291 and We will see what happened from there. If it still leaks I'm gonna sell the ****ty *** 2 piece and build my 1 piece seal block, I frigging hate 2 piece rear main seals.
Ford rear main seal question. el pollo Engine 3 07-15-2006 09:12 AM
Rear Main Seal? Pcr21688 Engine 6 06-26-2005 07:34 PM
55 chevy, 265 rear main seal slingslingbinks Engine 5 10-19-2004 09:27 AM
Rear main bearing cap question...SBC bennett Engine 1 06-20-2004 01:24 PM
rear main seal in 350 bstm23 Engine 4 12-02-2003 12:57 PM
