SBC rocker arm alighnment help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2006, 06:34 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
I searched the forum for answers but nothing solid came up. Im finishing my engine up, I have Edel perf RPM heads, w/ Jegs full roller rockers. All my valve tips and rocker tips except for 2 line up dead center with each other. One is about 70 to 80% in line but the exhaust rocker on #7 is 50 to 60% in line. the intake valve on #7 is dead on. So if I slot the guide plate to line up the ex. valve. that in turn will throw off the intake valve alignment. Does anyone know a fix for this?? or what is considered an acceptable alignment %?? Maybe split the difference?
Old 02-15-2006, 06:40 PM
NAIRB's Avatar
If you can't straighten it up by loosening the studs and moving the guide plates, you can invest in some adjustable guide plates. This is a very common problem. That's why I now prefer using self aligning rockers without guideplates.
Old 02-16-2006, 12:56 PM
johnsongrass1's Avatar
Race it, Don't rice it!
You might be able to cut the plate in half and adjust each side accordingly.
Old 02-16-2006, 05:36 PM
Bowtie or Die!
Thanks for the input guys. I got it straightened out I loosened the rocker studs and was able to get enough movement to correct the problem.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
SBC low oil press but no rocker arm noise? myclone614 Engine 14 01-23-2006 04:16 PM
SBC Rocker Arm Geometry radracer43 Engine 7 07-16-2005 10:44 AM
SBC Rocker arm Broke in 2 causes? mr_chickenhead Engine 14 04-22-2005 06:41 PM
stock rocker arm ratio 400 sbc taonindo Engine 1 08-08-2004 01:42 PM
