sbc rocker arm noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2011, 01:07 PM
i have a chevy 350 and it runs great i have harland sharp roller rockers on it 1.6 and it seems to raddle alot is it supposed to do that or what? thanks!
Old 12-31-2011, 01:30 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
What type of heads, got guide plates, posi locks? and what are the cam specs, hyd or solid lifter, amount of lift? did the noise start right out of the gate when the rockers were installed or did it come on gradually after a while?
Old 12-31-2011, 01:46 PM
it just has stock heads 70's the engine was just rebuilt no guide plates yes it started right away has posi locks and the cam specs are
Cam Style-Hydraulic flat tappet
Basic Operating RPM Range1,300-5,600
Duration at 050 inch Lift 218 int./226 exh.
Advertised Duration 262 int./270 exh.
Valve Lift with Factory Rocker Arm Ratio 0.462 int./0.480 exh.
Lobe Separation (degrees) 111
Old 12-31-2011, 02:01 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
More then likely the rocker geometry is off and it wouldn't hurt to have the guide plates also JMO. The rockers are probably all over the place on the valve tip IMHO.
Cole
Old 12-31-2011, 04:47 PM
Custom10's Avatar
Is this a comp XE cam or a Lunati voodoo?, also are the valve springs matched to the cam? Sorry no answers right now only more questions
Good point on the geometry Cole
Old 12-31-2011, 04:56 PM
Comp 4x4 and they are rated 300 at 1.250 so I think. They are
slight humming noise at idle and knocking? noise on slow acceleration zoomo Engine 13 05-26-2011 11:00 PM
SBC low oil press but no rocker arm noise? myclone614 Engine 14 01-23-2006 05:16 PM
rocker stud to rocker clearance 85406 Engine 2 07-16-2004 10:25 PM
Rocker Noise? 66chevy2ss Engine 8 09-06-2002 09:29 PM
noise subdude Hotrodders' Lounge 0 07-14-2002 04:14 AM
