Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc rocker arm not oiling?
Old 11-06-2012, 12:03 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by wibas View Post
I have been running the drill for about 30 minutes now while rotating the crank by hand. Still no oil from #5 exhaust. I cannot decide if I should pull the intake to get to the lifter or install the motor and start it up? I'm going to see if I have an old distributer to make an primer out of.
Info on dis- and re-assembling a hydraulic lifter can be seen here.
But if the engine has not yet been started for the first time, I would recommend you replace the entire lifter and be done w/it.
The bad lifter can be made into a solid lifter and used for checking the valve train geometry, so it won't be a total loss.
