sbc rocker arm not oiling?
I have a ZZ4 with about 20,000 miles on it. the motor has set for about 4 years. I'm getting ready to install it and fire it up. While still on the engine stand I thought I would prime the oiling system. #5 exhaust rocker is not oiling. So I pulled the rocker arm and push rod to blow air through. The rocker was clears and the pushrod had some oil in it but it still does not oil. I'm using a primer shaft with a 800 rpm drill. The guage shows 50 psi. Could it be a lifter fouled and if so will it pump better with the engine running? Or do I dig further?
I have been running the drill for about 30 minutes now while rotating the crank by hand. Still no oil from #5 exhaust. I cannot decide if I should pull the intake to get to the lifter or install the motor and start it up?
I'm going to see if I have an old distributer to make an primer out of.
But if the engine has not yet been started for the first time, I would recommend you replace the entire lifter and be done w/it. The bad lifter can be made into a solid lifter and used for checking the valve train geometry, so it won't be a total loss. |
I'm going to install the distributer and starter to give it a spin on the stand. Than when that does not work I will pull the intake and clean the lifters. Wish me luck. Thanks.
| sbc rocker arm noise | kevin383 | Engine | 5 | 12-31-2011 03:56 PM |
| SBC rocker arm/pushrod help | Ballpeen | Engine | 10 | 09-27-2011 08:06 AM |
| Sbc Rocker Arm Info | DARIN ALLMAN | Engine | 2 | 07-04-2007 10:26 AM |
| SBC rocker arm alighnment help. | 67 Deuce 4 Me | Engine | 3 | 02-16-2006 05:36 PM |
| SBC Rocker Arm Geometry | radracer43 | Engine | 7 | 07-16-2005 10:44 AM |
