SBC rocker arm nuts - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2013, 03:40 PM
SBC rocker arm nuts
As a newby to Chevy engine building, I'm not sure which way to seat the nuts on the rocker arms. Do they go tapered end down or flat side down, as I thread them in? I'm using a Haynes book and honestly, it's dreadfully written.
Old 03-20-2013, 04:20 PM
rocker arm nuts
rocker arm on stud first,pivot ball next then nut flat side down
Old 03-20-2013, 06:09 PM
Thank you much!
Old 03-20-2013, 11:53 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you're using stock lock nuts, they use a disrupted thread on the rounded side (facing up, below), so getting the nut to start on the stud is nearly- if not completely- impossible, unless the nut is correctly orientated on the stud (flat side down, as said). Replace these lock nuts if they've been used much; the self locking function loosens w/use.
Self locking rocker nuts can do a number on aftermarket studs, so use polylocs when possible. In some cases polylocs cause clearance problems w/the valve cover so check first. Using a thick or doubled gasket will sometimes give enough clearance. Using polylocs on stock studs will not always work- the polylocs need an even surface for the set screw to register on, often stock studs are uneven on the top.
Rocker Arm Lock Nuts 1965tripleblack Engine 4 07-07-2012 07:04 PM
SBC Poly Lock Rocker Arm Nuts hoops Engine 9 06-13-2012 09:43 AM
Rocker Arm Adjusting Nuts Problems - Help Me Diagnose leejoy Engine 8 11-26-2008 06:14 AM
SBC rocker arm alighnment help. 67 Deuce 4 Me Engine 3 02-16-2006 05:36 PM
SBC Rocker Arm Geometry radracer43 Engine 7 07-16-2005 10:44 AM
