SBC Rocker studs/poly lock s - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2012, 11:01 AM
OK, I am making a shopping list for Summit,What I need help with is studs (ARP). and polylocks to enable me to fit a stud girdle on a SBC head, do I need longer studs and poly locks or just the studs, reading some threads on the search function I see mention of people using 2" long studs , my heads have 7/16 " UNC studs.and are 1 1/2" long ish.the only other information that may be important is the valves are +.100 in lenght.Also using Comp Cams stainless roller rockers 1.5 Ratio.All input greatly appreciated .
Old 07-09-2012, 11:49 AM
The girdle will come with tall poly locks that fit the girdle. Longer studs may be a good idea but not necessary with the girdle. How much thread is available for the polylock to engage above the rocker arm currently?
Old 07-09-2012, 12:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Poor fitting girdles are worse than nothing, and unless you are using a lot of valve lift/valve spring tension and spinning it up, there's often no need for a girdle in the first place.
Providing you meet the criteria for needing a girdle, just be sure it fits right and doesn't cause the valve lash to change (usually tightens in my experience).
The polylocs come w/the girdle. You will need 7/16" studs, there's no sense in using 3/8". From the bottom of the hex to the end of the stud will be about 1.9"- 2.1", or what ever length is needed for the valve length and rocker arms you are running.
The Following User Says Thank You to cobalt327 For This Useful Post:
technicaltom (07-09-2012)
Old 07-09-2012, 07:40 PM
if your running 7/16 studs no need for a girdle
Old 07-09-2012, 08:31 PM
it all depends upon the lift of your cam up to .600 lift the 1.5 lenth will be fine over that you need the 2"
Old 07-10-2012, 04:46 AM
Thanks for your input,I am presently at .600 lift with 1.5 ratio rockers but same as most/all engine modifiers Im looking at more lift and maybe try 1.6 ratio rockers on the inlets in the future.
Old 07-10-2012, 06:09 AM
if your running 7/16 stud have that much thread showing off stud with rocker arm on and valves closed
Old 07-11-2012, 07:26 PM
no prob, your welcome, good luck with your mods.
hat
SBC Poly Lock Rocker Arm Nuts hoops Engine 9 06-13-2012 09:43 AM
Screw-in Rocker Studs (No Shoulder) - SBC - Torque Specs? kbuhagiar Engine 1 10-06-2010 10:08 PM
Removing Monkeyed up rocker studs (SBC) Silverback Engine 7 06-18-2010 03:32 AM
Threaded vs Pressed Rocker Studs (SBC) pgtr Engine 7 10-29-2004 07:10 PM
SBC Rocker Studs Question hiimed Engine 7 02-10-2003 05:18 PM
