SBC Roller block - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2006, 10:50 PM
47 Coupe's Avatar
SBC Roller block
Does anyone know what year they started putting roller cams in the SBC truck engines.
Thanks
Gary
Old 04-19-2006, 10:53 PM
'96 for trucks. Cars got them a few years earlier, around '87 or so. Truck motors from ~'87 up mostly were able to accept a factory roller cam, but the factory used flat-tappet cams in them for truck applications.
Beware, if it matters, that not all the roller blocks will accept a fuel pump push rod, and the only sure way to tell is to try to stick one in it.
Old 04-19-2006, 10:56 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
The engine blocks were set up for the roller cam in or around 1987-1988 or so. The did not use a roller cam in these years but the block was prepped for one.
Steve
Old 04-19-2006, 11:00 PM
47 Coupe's Avatar
So does that mean I can use the roller parts in the truck block?
Gary
Old 04-21-2006, 11:18 PM
Yes, as long as the block is set up for the roller cam. Look in the middle of the lifter valley and see if there are 3 small upwardly-protruding bosses with threaded holes in them, between the left & right lifter rows. The lifter guide retainer ("spider") bolts to these. Then look at the front camshaft hole, and see if there are two threaded holes alongside it. The camshaft retainer plate bolts to them.
roller cam in an non roller block..is it possible? bigshow2 Engine 5 09-18-2005 07:31 PM
SBC Block Questions Mustangsaly Engine 14 06-23-2005 10:14 AM
SBC Short block Tightening Torques & Procedure Houman SS '70 Engine 2 03-14-2005 05:23 AM
GM Roller cam/lifters in early style block ? SnakePliscan Engine 12 06-24-2004 05:28 PM
Old SBC to New OE SBC ROLLER LIFTERS??? juveteach Engine 2 04-27-2004 08:08 AM
